pipe cfd with pressure drop
Old   May 15, 2018, 08:37
Default pipe cfd with pressure drop
NA
umbsab988 is on a distinguished road
I have a pipe with a series of orefice plates and they have to give me a pressure drop of 30 bar ( from 34bar to 4bar). My aim is the mass flow rate. The pipe's diameter is of 60 mm and the orefices holes have a diameter 7mm up to 14mm (6 plates). The lenght of the pipe is 600mm initial velocity is 1.7 m/s.What kind of boundary conditions and input should I give, using a k-omega model?
umbsab988 is offline   Reply With Quote
Old   May 15, 2018, 19:00
Lucky
What is initial velocity? You mean velocity at the inlet? If you know the inlet velocity 1.1 m/s and pressure is 34bar, you pretty much already know the mass flow rate. What is the point of doing CFD?
To get a fixed pressure drop you'd set at the outlet, pressure of 3 bar. At the inlet, pressure of ~34 bar. Depending on your model you may be able to specify the static pressure or sometimes the stagnation pressure. Also you need an inlet static/stagnation temperature.
For k and omega, it depends what is upstream of your setup. But with a bunch of orifice plates I bet it does not influence the solution much.
Old   May 16, 2018, 01:58
piu58's Avatar
Uwe Pilz
piu58 is on a distinguished road
Form my experience, setting two pressures as b.c. is less stable than setting an inlet velocity. If your calculation time is not too high you may consider setting this bc. and change the velocity until you get the pressure drop you already know.
Uwe Pilz
Die der Hauptbewegung überlagerte Schwankungsbewegung ist in ihren Einzelheiten so hoffnungslos kompliziert, daß ihre theoretische Berechnung aussichtslos erscheint. (Hermann Schlichting, 1950)
piu58 is offline   Reply With Quote
Old   May 16, 2018, 04:41
NA
hi,
the temperature inlet is 20C° while the temperature outlet is 14 C°. I cannot use velocity inlet because the Mach number is very low at inlet and very high at outlet so it's a compressible folw and the Re=2.6e5. The time calculation is high. I use "gauge total pressure"= 3400058 Pa (absolute) and Supersonic/Initial Gauge Pressure =3400000Pa (absolute) at inlet (the inlet is positioned at a distance of 10*diameter from first plate) and 400000 Pa (absolute) at outlet
Old   May 17, 2018, 05:17
NA
if I use velocity inlet, what initial/supersonic gauge pressure and outflow gauge pressure I have to use at inlet? and at outlet?
Pressure drop in pipe flow with Large Eddy Simulation xerox FLUENT 1 October 16, 2019 09:55
Pressure drop over throttle disappears (simpleFoam --> pipe simulation) highpressuretube OpenFOAM Running, Solving & CFD 18 December 21, 2016 13:07
Pressure drop prediction in a pipe like structure violethill CFX 2 September 27, 2016 16:02
pressure drop air-water pipe Horizontal Mechaniker Fluent Multiphase 0 December 22, 2014 23:26
pressure drop in the pipe mike.mm FLUENT 6 February 7, 2011 11:31
