iterations process for steady solver and time dependence for unsteady |
#21 | |
Filippo Maria Denaro
Rep Power: 73 ![]() ![]() ![]() |
Well I strongly advice the use of the integral of the kinetic energy into the whole domain. In a statistically steady state, you should have a balance between production and dissipation. Therefore, if the plot of the total kinetic energy in time shows that it oscillates around an average (constant in time) value, you can consider that the numerical transient is over. |
#22 | |
Serguei
Rep Power: 11 ![]() |
#23 | |
Not sure about what you are doing but if you are prescribing a constant temperature that means you let the heat flux to asses from the solution. Therefore you can have part of the region having heat entering into the domain and part leaving, insn't that? |
iterations, steady, unsteady |
Segmentation fault when using reactingFOAM for Fluids | Tommy Floessner | OpenFOAM Running, Solving & CFD | 4 | April 22, 2018 12:30 |
Floating point exception error | lpz_michele | OpenFOAM Running, Solving & CFD | 53 | October 19, 2015 02:50 |
Star cd es-ice solver error | ernarasimman | STAR-CD | 2 | September 12, 2014 00:01 |
Moving mesh | Niklas Wikstrom (Wikstrom) | OpenFOAM Running, Solving & CFD | 122 | June 15, 2014 06:20 |
pimpleFoam: turbulence->correct(); is not executed when using residualControl | hfs | OpenFOAM Running, Solving & CFD | 3 | October 29, 2013 08:35 |
