UDF for terminal velocity
Old   May 2, 2018, 13:13
Default UDF for terminal velocity
Star
sikandar is on a distinguished road
I am dealing with a simple case of air water VOF modeling in 2D, where bubble moves with by buoyancy forces hence there is no inlet in bottom, the mesh is uniform, 60 by 600mm column and 3mm bubble is initialized at 10mm level.
how can i find the gravity center of bubble for accurate terminal velocity. If i have to write UDF kindly share any example or guide for this issue.
thanks
sikandar is offline   Reply With Quote
cfd - post, udf and programming, udf cg motion, udf code, udf c_vof
2D UDF for inlet y velocity Keyu Fluent UDF and Scheme Programming 1 April 26, 2016 06:01
Having trouble adapting serial UDF to work in parallel muyuntao Fluent UDF and Scheme Programming 1 November 10, 2015 14:42
Velocity boundary condtion UDF help victoryv Fluent UDF and Scheme Programming 2 October 9, 2012 16:27
Terrible Mistake In Fluid Dynamics History Abhi Main CFD Forum 12 July 8, 2002 10:11
UDF component in Cyliderical Velocity? Hongchan Kim FLUENT 3 April 24, 2001 13:20
