Same pressure gradient but different velocity field |
April 24, 2018, 04:37 |
#21 | |
Filippo Maria Denaro
Rep Power: 73 |
I think this solution has not really reached a convergence to steady state. If it does not converge that should confirm a bug in setting the BC. PS: are you using a small Re number? |
April 28, 2018, 01:46 |
#22 |
Actually, fixed total pressure at the inlet will give a different velocity profile. So it seems we cannot simply compare with Poiseuille solution.
April 28, 2018, 04:35 |
#23 | |
Rep Power: 73 |
At the steady state the solution has a constant velocity along x, therefore (p0_inl=p_inl + k_inl) and (p0_out=p_out + k_out) being k_out=k_inl should provide the same pressure difference. |
pressure and velocity, pressure boundaries, viscous laminar |
Pressure Inlet VS velocity Inlet difference | Mohsin | FLUENT | 9 | January 4, 2021 11:34 |
pisoFOAM (LES) - internal pipe flow - convergence | gu1 | OpenFOAM Running, Solving & CFD | 0 | January 11, 2018 17:39 |
Moving mesh | Niklas Wikstrom (Wikstrom) | OpenFOAM Running, Solving & CFD | 122 | June 15, 2014 07:20 |
WSS and normal velocity gradient for the slanted pipe | wanna88 | FLUENT | 2 | October 1, 2012 23:34 |
Terrible Mistake In Fluid Dynamics History | Abhi | Main CFD Forum | 12 | July 8, 2002 10:11 |
