Best Practices to Simulate Rotational component
Old   April 6, 2018, 01:48
Smile Best Practices to Simulate Rotational component
Vignesh Veeresparan
vizvaz is on a distinguished road
Hi All,
This question is not specific to any CFD tool and I would like everyone to share thier experiences on fans & Pump simulation.
Basically, I wanted to find the the fan/pump performance using CFD. I'm using MRF method to simulate the fan blade / pump impeller rotation.
Below are the Boundary conditions that are specified
1. Inlet/Suction - Mass flow rate / Total pressure
2. Outlet/Discharge - 0 Pa Static Pressure
3. Rotating Blades / Impellers - Angular velocity at selected point in performance curve
4. Rotating Domain - Angular velocity at selected point in performance curve
5. Shroud / Casing - No Slip Condition
When the simulation is run for all the selected points on performance curve. It is observed that when the fan/pump is operated at off design points the results are deviating more than 30% and its not acceptable. So, it becomes very difficult to judge the performance of the rotating machineries with MRF method in CFD.
It would be really helpful, if you could share me your experience in simulating fan/pump and share your views in addressing this kind of problems.
Regards,
Vignesh
vizvaz is offline   Reply With Quote
fan, mrf, pump
What is the difference in connecting geometry component to mesh in Workbench? arjdk ANSYS 0 November 15, 2017 06:23
Multiphase flow - incorrect velocity on inlet Mike_Tom CFX 6 September 29, 2016 02:27
Momentum source coefficient, cylindrical coordinates, circumferential component? polakse CFX 15 January 18, 2016 03:40
How to get the x component of a point? Gerwang OpenFOAM Programming & Development 1 January 11, 2016 08:18
max rotational velocity of VAWT by CFD CFD-beginner Main CFD Forum 0 April 5, 2010 00:04
