April 3, 2018, 12:47 |
Rotational Velocity in Workbench
Ata Aganoglu
I am working on a model and it involves a ball rotating inside of a cage bearing. I did a simplified model for easier simulation. My goal is to analyse the stress on the rings while the ball rotates. You can find the image in the link below. (don't consider the points on the ball in the middle- deleted them afterwards.) However, even though I have given no separation condition in the contacts (also not sure about that ) and named my parts and selected fixed support for the rings, the mesh fails. Does anyone have any idea how to solve this issue? Failed mesh image: https://drive.google.com/file/d/1aI8...ew?usp=sharing |
rotational motion, structural analysis, workbench ansys 18 |
UDF Changing Rotational Velocity | sdarmayuda | Fluent UDF and Scheme Programming | 0 | September 18, 2017 10:36 |
VELOCITY vs VELOCITY IN STN FRAME vs RELATIVE VELOCITY | everest20 | FLUENT | 1 | July 13, 2015 08:35 |
WSS and normal velocity gradient for the slanted pipe | wanna88 | FLUENT | 2 | October 1, 2012 22:34 |
udf for changing rotational velocity | peterchen | Fluent UDF and Scheme Programming | 4 | October 19, 2010 06:43 |
what the result is negatif pressure at inlet | chong chee nan | FLUENT | 0 | December 29, 2001 05:13 |
