Non Newtonian fluids: gravity or no gravity ? |
April 1, 2018, 08:59 |
macaffy
Rep Power: 9 |
hello, I have a quick question for you. I have a square cross section (64μm^2) microfluidics channel. The fluid flow is parallel to the xz plane (with the yy' to be the vertical axis). My fluid is the blood and I used the Bird-Carreu formula for modeling it. Also my flow is pressure driven ( I have applied an inlet velocity and I set the outlet pressure to be 0 Pa). Do I have to take into account the gravity or not?
April 1, 2018, 13:04 |
Uwe Pilz
Rep Power: 15 |
Of course you need to take into account the gravity.
BTW: A giraffe has an systolic pressure of around 400 to fight against the gravity. For not to get varices they has some kind of elastic stockings.
Uwe Pilz -- Die der Hauptbewegung überlagerte Schwankungsbewegung ist in ihren Einzelheiten so hoffnungslos kompliziert, daß ihre theoretische Berechnung aussichtslos erscheint. (Hermann Schlichting, 1950) |
April 1, 2018, 13:16 |
macaffy
Rep Power: 9 |
Thank you for your answer! I was thought that the only case we can take gravity into account was when the fluid flows vertically in a pipe or when a pipe is tilted.
April 1, 2018, 13:17 |
Alex
Rep Power: 49 |
I assume Uwe is just teasing you. A giraffe ist just about the opposite of what you are trying to simulate: macro-channel with gravity pointing in stream-wise direction vs. micro-channel with gravity pointing cross-stream.
The safest/easiest way to check (i.e. without making some estimates) is by just running both simulations and comparing the results. |
April 1, 2018, 13:24 |
macaffy
Rep Power: 9 |
Yes I know that I have to do this eventualy ... but my laptop is not very good and it realy takes a lot to give me a result ... So I was hopping for someone to give me an answer. What parameter should I test? Is the pressure in the middle of the channel a good indicator? I am studying a FSI problem.
April 1, 2018, 13:28 |
Filippo Maria Denaro
Rep Power: 73 |
Gravity is important in a complete real circulation but if you are modelling such a small channel, the body force can be neglected compared to the pressure driven force.
fluid flow, fuids, microfluidics, non newtonian |
Non- Newtonian fluids | Iman Sengupta | FLUENT | 0 | June 30, 2015 09:27 |
gravity driven rigid body motion in fluids | tsh850227 | CFX | 8 | January 6, 2014 05:20 |
Simulating two fluids in zero gravity environment | siw | CFX | 6 | February 12, 2010 05:38 |
Low reynolds model for non newtonian fluids | Kimo | FLUENT | 0 | July 22, 2007 11:36 |
spraying non newtonian fluids | Iñigo | Main CFD Forum | 0 | October 4, 2005 09:36 |
