Conjugate Heat transfer between Twofluidszones |
March 28, 2018, 03:02 |
Ramana
Rep Power: 9 |
i have a problem for which i have not found solution so far. i have two cubes the smaller one (porous cylinder) surrounded by bigger cube(air)I am trying to setup case which involves conjugate heat transfer from a porous cylinder to surrounding fluid(air) through forced convection. Code:
cfd domain.png the flow properties are T air=283, Re=40 ,Pr =0.7 and permeability K=10^-2. Code:
BlockMesh used to mesh the two regions in a single meshing operation, where the internal cylinder is meshed as a cellZone and the porosity is later assigned with an fvOption. now i need to assign fixed temperature to porous cylinder and simulate heat transfer between cylinder and surrounding fluid. Can i use fixed temperature constraint(with limited exposure i have, it is applicable to compressible flow) how to define heat transfer interface conditions between two regions(both are defined as fluids) Thanks in advance Regards, Ramana |
conjgate heat transfer, incompressible, porous boundary |
Difficulty In Setting Boundary Conditions | Moinul Haque | CFX | 4 | November 25, 2014 17:30 |
VOF with conjugate heat transfer | vs138 | Fluent Multiphase | 1 | November 12, 2014 08:52 |
fireFoam - conjugate heat transfer | Duy Le | OpenFOAM Programming & Development | 0 | October 2, 2014 10:48 |
conjugate heat transfer in porous media-variable HTC | hmasenger | CFX | 3 | June 21, 2014 07:57 |
Conjugate Heat transfer in CFX | ksp1717 | CFX | 11 | December 10, 2010 22:07 |
