April 6, 2000, 11:57 |
airfoil-litterature
Hi all,
I'm involved in studying an airfoil for racing cars. At the moment I'm trying a good mesh using a NACA 6-series profile. Does anyone point to me a papers (or anything else) in which I could find a compareison between experimental data (Wind Tunnel)and numerical simulation for drag and lift coefficients? Maria Teresa |
April 13, 2000, 22:30 |
Re: airfoil-litterature
There is an extensive appendix in: "Theory of Wing Sections" By Abbott and Von Doenhoff That has some experimental data on NACA airfoils. You should be able to get a good sense of your results from this reference. The book only has experimental data. As for comparisons, you should be able to find a couple of papers dealing with airfoils as code and/or turbulence model test cases.....I have seen a few on the NACA 00XX, GAW(1)--LS0417, and NLF series airfoils. I don't know what foil you are looking at, but if you need more help I *may* be able find more if you have some more details (what Airfoil?, Code type(FVM, FD, FEM and turbulence model assumptions) etc.). Anyways....good Luck with the modelling....hope this helps, DjW |
Low Speed Airfoil | Mancusi | FLUENT | 7 | April 3, 2014 07:11 |
[GAMBIT] Meshing airfoil using .dat file problem | creggie | ANSYS Meshing & Geometry | 10 | June 27, 2010 20:24 |
Poor Residuals at Intersection Between Symmetry Plane and Airfoil Leading Edge | TWaung | CFX | 2 | February 16, 2010 09:11 |
Modeling Backflow for a 3D Airfoil (Wing of Finite Span) | Josh | CFX | 9 | August 18, 2009 12:31 |
Airfoil boundary condition | Frank | Main CFD Forum | 1 | April 21, 2008 19:36 |
