Approximate Solution to a System of Linear Equations |
March 12, 2018, 05:19 |
abcd efgh ijkl
Rep Power: 11 |
Hello everyone,
I hope you having a good day. Consider a linear system, Ax=b where A is coefficient matrix, x is vector of variables whose values we want to find out, and b is a vector of constants in which all entries are same. Is there a way to find out relative values of xi (entries of x) without actually solving the system of equations. In other words, can say by just looking at A that x1 will be greater than x2 because the sum of entries of first row is greater than the sum of entries of 2nd row of A. I have intentionally made the assumption that all entries of b are same, so that they have no effect on our approximate solution. Thank you! |
March 12, 2018, 05:31 |
#2 | |
Filippo Maria Denaro
Rep Power: 73 |
The traditional way to get an approximate solution is to use iterative method wherein you do not invert the matrix. You can control the residual at each iteration. I dont understand why are you considering the sum of the entries of A. |
March 12, 2018, 06:34 |
abcd efgh ijkl
Rep Power: 11 |
Dear Filippo Maria Denaro,
I am trying to develop a stabilized method for hyperbolic equations using meshless methods. The method I described above is used in Finite Element Method and is known as Row Sum Lumping. I have tried to solve a system of equation using this method and the results are very inaccurate. I might have made a mistake. I will get back to you soon after revising the method. Thank you. |
March 12, 2018, 06:39 |
Rep Power: 73 |
Consider the vector of the residual at a certain k-th iteration. Each entry of this vector is the sum of the entries in the corresponding row of A, multiplied the components of the approximate solution at the stage k minus the components of the known term. In vector notation:
A.x_k-q= r_k I suppose this is what you are trying to control, isn't that? |
linear algebra, system of equations |
Steady-State and Transient Solvers | 70m1 | OpenFOAM Running, Solving & CFD | 21 | May 8, 2021 08:09 |
Sysyem of linear equations | soes | Main CFD Forum | 6 | March 18, 2016 01:56 |
Solver for system of hyperbolic equations | treima | OpenFOAM Programming & Development | 1 | October 21, 2012 10:34 |
Analytic solution for 2D steady Euler equations | jojo81 | Main CFD Forum | 0 | October 15, 2012 13:05 |
CFX11 + Fortran compiler ? | Mohan | CFX | 20 | March 30, 2011 19:56 |
