March 9, 2018, 03:01 |
Quick Scheme for supersonic reacting flows
ARAVIND SRIDHARA
Rep Power: 9 |
Hii all
i am solving a problem on 3d supersonic flow with flamelet model for chemical kinetics with 10 species and k-e turbulence model. i employ coupled solver to solve for pressure. i had initially employed second order for all other variables (energy, density,momentum, turbulent kinetic energy, mixture fraction) then later on after few thousand iterations i changed my solution methods to quick scheme for (density, momentum, energy) and retained second order for (turbulent kinetic energy, and mixture fraction). indoing so my mass imbalance and residuals have increased. is it beacuse of quick scheme ? is quick scheme be used for this complex flows? please let me know on this thank u for your time |
March 9, 2018, 19:01 |
Lucky
Rep Power: 66 |
You should mention that you are using Fluent because QUICK is not the same in all codes.
Residuals are higher, but the solution is still stable right? And do you mean the residuals converged to higher values or they just spiked after you changed settings? You should expect a spike in residuals whenever you change anything. My first guess which be to keep density discretization as before to help stabilize the p-v coupling. In general, QUICK is slightly higher order and hence more unstable than 2nd order upwind. |
March 10, 2018, 16:40 |
ARAVIND SRIDHARA
Rep Power: 9 |
Thank u for the reply
Yes I am using fluent. Yes the residuals hv spiked up n came back , the solution is not stable yet . The mass imbalance has also increased. N residuals r getting stable at higher value as compared to second order in terms of magnitude |
quick scheme, reacting, reacting flows, second order schems, supersonic flows |
Problem in coding QUICK scheme for convection term | mahdi_kh8 | Main CFD Forum | 1 | February 17, 2014 04:25 |
Upwind, central, QUICK scheme for Re~10000 | quarkz | Main CFD Forum | 4 | June 23, 2011 16:04 |
can u suggest me a paper to benchmark the code for quasi-1d reacting flows | RAMIREDDY.V.MUVVA | Main CFD Forum | 0 | April 25, 2000 05:51 |
TVD scheme applied to axsymetric nozzle flows | Zhou Hua | Main CFD Forum | 0 | May 7, 1999 01:10 |
ability of fluent to predict scalar fields in reacting flows ? | Mounir | Main CFD Forum | 1 | January 21, 1999 11:08 |
