Derivation of Energy Equation
Old   February 25, 2018, 08:45
Default Derivation of Energy Equation
abcd efgh ijkl
alibaig1991 is on a distinguished road
Hello everyone,
I hope this finds you well.
In the research paper titled "Derivation of stabilized equations for numerical solution of advective-diffusive transport and fluid flow problems", the author has given an expression for stabilized form of 1 dimensional energy equation for a compressible fluid.
I am trying to derive this result. I have tried a few times but I am making mistakes, specifically in the sign of thermal conduction term and the velocity u in the first derivative on the RHS of Eq. 76. In my result, the sign of thermal conduction is minus, and the velocity u comes inside the derivative.
Can someone help me? Where am I making mistake?
Thank you.
alibaig1991 is offline   Reply With Quote
Old   February 26, 2018, 05:31
Filippo Maria Denaro
FMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura about
If I assume h=0 and Q=0, I see the correct form of the total energy conservation, no error in the heat flux term.
FMDenaro is offline   Reply With Quote
Old   March 25, 2022, 03:09
Lucky
Check that you have appropriately applied Fick's law. Heat/enegy flows down temperature gradients from high temperature to low temperature and there's a minus sign for the conductive heat flux.
To put the u inside (or take it out of the derivative), apply the product rule and use the continuity equation.
governing equation
Error in computing Energy equation faab OpenFOAM Running, Solving & CFD 0 February 3, 2017 14:04
Solving the total energy equation dohnie OpenFOAM 21 June 13, 2014 01:44
Pyrolisis energy equation yaqb OpenFOAM Programming & Development 0 May 22, 2014 18:25
problem on energy and flow equation solving separately preetam69 FLUENT 2 July 30, 2013 22:08
SIMPLE and energy equation convergence Fabio Main CFD Forum 0 June 1, 2007 07:06
