Mathematica: steady-state compressible air viscous flow in a 2D axisymmetric step |
#1 | ||
Foad
Rep Power: 9 ![]() |
I have also posted my question here in StackExchange and also my code here in this GitHub Gist.
I'm trying to follow this post using Mathematica to solve Navier-Stokes equations for a compressible viscous flow in a 2D axisymmetric step. The geometry is in the attachment. Defining variables, geometry and meshing: Code:
lc = 0.03; rc = 0.01; xp = 0.01; c = 0.005; rp = rc - c; lp = lc - xp; T0 = 300; eta0 = 1.846*10^-5; P1 = 6*10^5 ; P0 = 10^5; cP = 1004.9; cnu = 717.8; R0 = cP - cnu; Omega = RegionDifference[Rectangle[{0, 0}, {lc, rc}], Rectangle[{xp, 0}, {xp + lp, rp}]]; Needs["NDSolve`FEM`"]; mesh = ToElementMesh[Omega, "MaxBoundaryCellMeasure" -> 0.00001, MaxCellMeasure -> {"Length" -> 0.0008}, "MeshElementConstraint" -> 20, MeshQualityGoal -> "Maximal"]; Where the model is axisymmetric around the x axis, the governing equations including conservation equations of mass, momentum and heat can be written as: ![]() ![]() ![]() forth equation is big so I add it as a image in the attachments. Implementing the equation is Mathematica: Code:
eqn1 = D[rho[x, r]*nux[x, r], x] + D[r*rho[x, r]*nur[x, r], r]/r == 0; eqn2 = D[rho[x, r]*nux[x, r]^2 + R0*rho[x, r]*T[x, r], x] + D[r*(rho[x, r]*nux[x, r]*nur[x, r] + eta0*D[nux[x, r], r]), r]/ r == 0; eqn3 = D[rho[x, r]*nux[x, r]*nur[x, r] + eta0*D[nur[x, r], x], x] + D[r*(rho[x, r]*nur[x, r]^2 + R0*rho[x, r]*T[x, r]), r]/r == 0; eqn4 = cnu* rho[x, r]*(nux[x, r]*D[T[x, r], x] + nur[x, r]*D[T[x, r], r]) + R0*rho[x, r]* T[x, r]*(D[nux[x, r], x] + D[r*nur[x, r], x]/r) + (2*D[nux[x, r], x]^2 + 2*D[nur[x, r], r]^2 + (D[nux[x, r], r] + D[nur[x, r], x])^2 - ((D[nux[x, r], x] + D[r*nur[x, r], x]/r)^2)*2/3)* eta0 == 0; eqns = {eqn1, eqn2, eqn3, eqn4}; And the boundary conditions are:
Implemented in Mathematica as: Code:
bc1 = R0* rho[0, r]*T0 == P1; bc2 = R0 *rho[lc, r]*T0 == P0; bc3 = DirichletCondition[{nur[x, 0] == 0, D[nur[x, r], r] == 0, D[nux[x, r], r] == 0, D[rho[x, r], r] == 0, D[T[x, r], r] == 0}, r == 0 && (0 <= x <= xp)]; bc4 = DirichletCondition[{nur[x, r] == 0, nux[x, r] == 0}, (0 <= r <= rp && x == xp) || (r == rp && xp <= x <= xp + lp) || (r == rc && 0 <= x <= lc)]; bcs = {bc1, bc2, bc3, bc4}; Code:
{nuxsol, nursol, rhosol, Tsol} = NDSolveValue[{eqns, bcs}, {nux, nur, rho, T}, {x, r} \[Element] mesh, Method -> {"FiniteElement", "InterpolationOrder" -> {nux -> 2, nur -> 2, rho -> 1, T -> 1}, "IntegrationOrder" -> 5}] Quote:
air, axisymmetric, compressible, mathematica, viscous |
Steady state free surface flow in rotational closed system | hilde | CFX | 5 | January 21, 2015 16:47 |
Constant velocity of the material | Sas | CFX | 15 | July 13, 2010 08:56 |
Could anybody help me see this error and give help | liugx212 | OpenFOAM Running, Solving & CFD | 3 | January 4, 2006 18:07 |
steady state creeping flow | dominik | Main CFD Forum | 4 | March 29, 2004 09:29 |
About the difference between steady and unsteady problems | Lisa | Main CFD Forum | 11 | July 5, 2000 14:37 |
