Calculation of Mesh Velocities using GCL for triangular mesh elements
Old   February 13, 2018, 06:49
Default Calculation of Mesh Velocities using GCL for triangular mesh elements
Kartik Bali
Petrucci is on a distinguished road
Hello everybody!
I was modifying an FV 2D Incompressible NS Solver ,which uses flux reconstruction method for a triangular element, to solve for flow past an oscillating cylinder using ALE set of NS Equations.
From what I can infer from the literature I referred, i.e to solve the ALE equations using the mesh velocities calculated from GCL(or SCL) equation to obtain the convective velocity and their substitution in modified convective terms, how do I calculate mesh velocities for the triangular element(since there are multiple such velocities which can satisfy gcl)?
Any help would be highly appreciated.Thanks!
Petrucci is offline   Reply With Quote
ale, flux reconstruction, gcl
sliding mesh problem in CFX Saima CFX 46 September 11, 2021 08:38
FFD shape deformation for 3D wing not changing the mesh lwc24 SU2 Shape Design 5 August 1, 2019 16:17
[ICEM] Nuclear fuel assembly, Mesh Check: "missing internal faces, uncovered faces" swparth ANSYS Meshing & Geometry 2 June 27, 2017 08:12
2d irregular grid Remy Main CFD Forum 1 December 22, 2008 05:49
CFX4.3 -build analysis form Chie Min CFX 5 July 13, 2001 00:19
