Meshing and Solver Settings dealing with high pressure gradients
Like Tree1Likes
Old   February 9, 2018, 09:30
Default Meshing and Solver Settings dealing with high pressure gradients
Hells Blade
hellsblade.91 is on a distinguished road
Hi all I have some queries
I am simulating the flow of air at 6 bars of pessure through a domain with different inlet geometries and comparing the mass flow and velocity at my outlet. In one of the sims contour attached - I am getting max wall y + value upto 189 (when I added an inflation layer of 5.3e-3 mm)
As per K epsilon model it should be within a range of 30 to 300
for another inlet geom my wall y + is too high more than 1e3 ( not working with the same first layer thickness value of 5.3e-3 mm)
I am trying to check the mesh sizing at inlet
Currently I have 150 div at inlet which is 90 mm dia and 300 mm long
When i try to increase my no of division to 800 the meshing is taking too much time I am not sure when this would finish
Can some one please comment how do i attain all y + in this range 30-300 or is it not required as my goal is just to check vel and mass flow at my outlet (lower face of the domain attached)
I am using Kepsilon Model
Coupled Solver
Pressure Inelt Bc - 6 Bar ( Should I also define something at superonic inlet condition at pressure inlet as 6 bars of pressure would lead to supersonic vel as also seen in vel results )
Pressure Outlet Bc - 1 bar
Also while checking the velocity at my outlet which values should I consider
is the area weighted average , max minmia at outlet (from CFD PosT)
Kindly give your suggestions
Thanks
hellsblade.91 is offline   Reply With Quote
Old   January 4, 2022, 16:09
Sebastian Zermeno
zermenos is on a distinguished road
Hello
i know it's quite old but did you manage to do it? I'm having the same problem with a high pressure difference using rhoPimpleFoam
What do you recommend?
Thanks
zermenos is offline   Reply With Quote
How to read pressure at discrete points paka OpenFOAM 16 April 28, 2020 08:26
Error: Divergence detected in AMG solver: pressure correction wanna88 FLUENT 19 April 6, 2016 03:57
[ICEM] icem meshing + cfx solver sandy_1982 ANSYS Meshing & Geometry 7 February 24, 2014 13:44
Wedge Impact Forces (6DOF high velocity problem) der_meister FLUENT 1 June 15, 2010 00:32
CFX 5.5 Roued CFX 1 October 2, 2001 17:49
