PLIC-VOF with a Conservative formulation at high density ratio |
Abhishek
Rep Power: 8 ![]() |
Greetings!
I am trying to develop a Two Phase VOF solver with a conservative formulation. I have successfully implemented the following:
Rep Power: 13 ![]() |
Basically what you have to do is not to use the average density for the interface density in the mass flux. Rather use a mass flux, which is calculated from the mass fluxes of the two phases:
if the face densities for the two phases are ![]() ![]() ![]() ![]() ![]() Now, the volume flux for the second phase ![]() ![]() Now just use these two volume fluxes to calculate the mass flux using the density for the two phases on the face seperately: ![]() This procedure worked very well for me. I can't give you a reference though, because I kind of came up with it myself. However, I am fairly sure someone has done and published it before. Last edited by beer; February 9, 2018 at 10:27. |
Abhishek
Hello! Thanks for the reply. Are you suggesting that the density at the faces should be calculated using the amount of both fluids present in the volume (face velocity*dt)*A?
No, sorry I should have stated that. You should calculate the face density for each phase seperately. I edited my answer above.
Abhishek
Sorry but i still dont get what you are trying to say. Where do i need to use the mass flux?
Nikhil
Rep Power: 10 ![]() |
Dear Abhishek,
This is caused due to disparity in Gamma (specific heat ratio calculation) Please refer the following paper, https://www.sciencedirect.com/scienc...21999115005021 titled "Preventing numerical oscillations in the flux-split based finite difference method for compressible flows with discontinuities". As this paper is highly condensed you might have to cross refer the references for more details. Regards, |
Saideep
Rep Power: 12 ![]() |
Might be of use. A simple way is to filter the volume fraction several times so that you dont see a sharp jump in the fluid properties but a gradual jump. This is something that the software "Gerris Flow Solver" using PLIC-VOF does.
However, I did find that for some density ratios (air water) keeping the viscosity ratio as 1, the solver really struggles. |
conservative form, twophase fluid, volume of fluid |
pressure eq. "converges" after few time steps | maddalena | OpenFOAM Running, Solving & CFD | 69 | July 21, 2011 07:42 |
Problem on high density ratio in Level Set method | Kai Yan | Main CFD Forum | 10 | December 25, 2007 06:12 |
conservative total pressure and density | Atit Koonsrisuk | CFX | 0 | June 24, 2007 12:45 |
VOF formulation | mvee | FLUENT | 3 | March 12, 2007 06:35 |
Specified Operating Density for Compressible VOF | Andrew Wick | FLUENT | 1 | November 14, 2005 04:58 |
