how to find nusselt number at stagnation point for jet impingment |
February 7, 2018, 10:37 |
help needed Nusselt number at stagnation point for jet impingment
waqar hazoor
Rep Power: 9 |
can anyone tell me the steps to calculate nusselt number in fluent. case is jet impingement, transient case, plate at constant temperature of 900K air jet at 300k. how to find nusselt number at stagnation number, i calculated the nusselt number but it gives me wrong values from higher values to lower but in figure as shown it should be start from lower value to higher. tried every thing but not getting how to do that.
by wall fluxes >total surface heat flux and then find h and then Nusselt by wall func heat transfer coef and then nusselt number by surface heat transfer coeff and nusselt number by direct finding surface nusselt number can anyone here help me how to find it what is the right way. Last edited by waqarha2003; February 27, 2018 at 12:40. |
[Other] Can't Shake Erros: patch type 'patch' not constraint type 'empty' | BrendaEM | OpenFOAM Meshing & Mesh Conversion | 12 | April 3, 2022 18:32 |
block-structured mesh for t-junction | Robert@cfd | ANSYS Meshing & Geometry | 20 | November 11, 2011 04:59 |
DecomposePar unequal number of shared faces | maka | OpenFOAM Pre-Processing | 6 | August 12, 2010 09:01 |
Unaligned accesses on IA64 | andre | OpenFOAM | 5 | June 23, 2008 10:37 |
[Commercial meshers] Trimmed cell and embedded refinement mesh conversion issues | michele | OpenFOAM Meshing & Mesh Conversion | 2 | July 15, 2005 04:15 |
