Stability Analysis of Hyperbolic Problem
Old   January 28, 2018, 16:37
Default Stability Analysis of Hyperbolic Problem
abcd efgh ijkl
alibaig1991 is on a distinguished road
Hello everyone,
I hope this finds you in good health.
I was reading the book "Numerical Computation of Internal and External Flows" Vol.1 by Charles Hirsch. In the Chapter of Von Neumann stability analysis, the author has stated two relations, one for exact dispersion (7.4.18) and the second for typical harmonic of solution u (7.4.19). Can anyone help me with their derivation or guide me where can I find more details about these relations.
Please see the attached image.
alibaig1991 is offline   Reply With Quote
Old   January 28, 2018, 16:54
Filippo Maria Denaro
FMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura about
Considering the linear equation on a periodic domain you can see that, according to a Fourier series, a real solution u(x,t) can be written as a sum of products of two complex Uk(t)*exp(i*k*x). By substituting it in the equation, you can easily see that Uk(t)=Uk(0)*exp(-i*k*a*t). Therefore:
u(x,t) = Uk(0)*exp[i*k*(x-a*t)]
The unitary amplification factor simply states that the initial function u(x,0)=Uk(0)*exp(i*k*x) is convected rigidily at a constant velocity a.
Now, consider any discretization of the previous equation. Substitute the Fourier components in it and see what happens to the resolved field by means of the amplification factor
FMDenaro is offline   Reply With Quote
Old   January 29, 2018, 11:37
abcd efgh ijkl
Dear Sir, thank you so much. Have a good day!
stability analysis, von neumaa
Thermal Analysis Problem ChristianGermany ANSYS 1 September 26, 2015 14:42
dirichelet boundary conditions for hyperbolic problem Hooman Main CFD Forum 4 August 12, 2015 18:26
Problem in conducting CFD of analysis of wind turbine blade atulpat CFX 16 August 17, 2013 05:09
Problem with DES analysis mehul CFX 7 April 25, 2006 08:57
help: analysis solution of gas-water sod problem gooo Main CFD Forum 0 April 19, 2005 02:05
