How to model the flow past cylinder with transitional Re Number |
January 23, 2018, 19:41 |
Rep Power: 9 |
I am modeling air flow past a circular cylinder. According to the air velocity and the dimensions of the cylinder, the Re number of air flow is about 350. This number, according to the literature is within the critical Re for flow past a cylinder.
I would like to know, which flow regime best describes the conditions in my simulations; laminar for turbulent. Thanks |
January 23, 2018, 20:56 |
Alex
Rep Power: 49 |
Transitional
The most accurate way to simulate this would be a DNS, and it should be feasible on any modern PC. |
January 23, 2018, 22:55 |
#3 | |
Rep Power: 9 |
I am using COMSOL to model the air flow. My question is that in case Re number is within transition range, which is the case in my modeling, should I use laminar flow or turbulent flow? Thanks |
January 24, 2018, 07:17 |
Filippo Maria Denaro
Rep Power: 73 |
DNS (Direct Numerical Simulation) means you resolve the 3d unsteady NS equations using a grid enough fine to solve up to the Kolmogorov scale of the flow problem without any other assumption on the regime of the flow.
Drag force coefficient too low for a flow past cylinder at Re= 1e05 | Scabbard | STAR-CCM+ | 2 | June 5, 2020 15:44 |
Flow past a cylinder at Re 1e05 using LES, drag force coefficient is to low | Scabbard | Main CFD Forum | 21 | June 19, 2018 14:58 |
Compressor Simulation using rhoPimpleDyMFoam | Jetfire | OpenFOAM Running, Solving & CFD | 107 | December 9, 2014 14:38 |
parallel code | samiam1000 | SU2 | 3 | March 25, 2013 05:55 |
[Commercial meshers] Trimmed cell and embedded refinement mesh conversion issues | michele | OpenFOAM Meshing & Mesh Conversion | 2 | July 15, 2005 05:15 |
