What is linear eddy viscosity
Old   January 12, 2018, 10:00
Default What is linear eddy viscosity
toboto
toboto is on a distinguished road
Dear all,
I was reading about turbulence modeling (a topic which I am not expert in) and I was puzzled by the discussion about linear vs. nonlinear eddy viscosity.
Most references (including CFD-online wiki) say that in linear eddy viscosity models the Reynolds stresses are linearly related to mean strains via the
turbulent, or eddy, viscosity.
But from my basic understanding, eddy viscosity is dependent on turbulence variable (e.g. k & epsilon) which in turn depend on the flow field. So, eddy viscosity actually depends on the flow field. This is similar to non-Newtonian viscosity (correct me if I am wrong)
So, how can linear eddy viscosity model exist?
toboto is offline   Reply With Quote
Old   January 12, 2018, 11:04
Filippo Maria Denaro
FMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura about
Originally Posted by toboto View Post
Dear all,
You are right about the ambiguity in the nomenclature. The eddy viscosity is a function of the resolved velocity even in the linear relation. The nomenclature mimics the linear relation used for newtonian fluid. Actually, we could say that appears linear in the functional relation, not mathematically.
Check also in the books of Pope and Wilcox.
FMDenaro is offline   Reply With Quote
Old   January 12, 2018, 19:30
Lucky
Assume that you magically know the eddy viscosity (say via a hotline to God). For demonstrative purposes, forget that we will call it eddy viscosity or that it is a flow property. Then the linear eddy viscosity relates the reynolds stresses to the strain (i.e. the linear functional relation between the two). This is all that the (linear) eddy viscosity model claims. No one says (yet) how the heck you can find this eddy viscosity yet. Of course other models do not have this simple linear proportionality relation but more complex ones.
How to find this linear coefficient which we call eddy viscosity is another matter.
linear eddy viscosity, turbulence modeling
Problem with divergence TDK FLUENT 13 December 14, 2018 07:00
How do we calculate the normal Reynolds stresses? (Linear eddy viscosity models) userid42 Main CFD Forum 8 August 28, 2017 14:11
2nd Order Convergence Problem for 3D Airfoil turkmengokce OpenFOAM Running, Solving & CFD 1 September 10, 2015 08:20
A turbulent test case for rhoCentralFoam immortality OpenFOAM Running, Solving & CFD 13 April 20, 2014 07:32
Ratio of eddy viscosity to molecular viscosity : Laminar or turbulent flow? JuPa CFX 7 September 9, 2013 08:45
