steady compressible axisymmetric isothermal flow of Newtonian fluid in conical tube
Old   January 11, 2018, 16:34
Question steady compressible axisymmetric isothermal flow of Newtonian fluid in conical tube
Ivanjica is on a distinguished road
I consider steady compressible axisymmetric isothermal flow of Newtonian fluid-gas in conical tube at low Re numbers.
According to problem I have governing equations in cylindrical coordinates. Because of symmetry one component of velocity is $u_\phi=0$ and because it is steady flow $\dfrac{\partial}{\partial t}=0$.
I am not sure what is happening with radial velocity $u_r$, is it with little variability, so can I ignore terms which consist $u_r$ and derivative of $u_r$ or not? And is there any other simplification according to type of flow?
Couple steps after these I need to make NS equations simpler using Mach number, so is it possible define Mach number according to both velocities $u_r$ and $u_z$, because I will have it both? $u_z$ is longitudinal velocity and it exist.
Ivanjica is offline   Reply With Quote
compressible flow, conical tube, flow conditions, navier stokes equation
Help regarding 1D compressible flow (Sod Shock tube) selig5576 Main CFD Forum 40 August 29, 2022 07:33
Wrong flow in ratating domain problem Sanyo CFX 17 August 15, 2015 07:20
Solver for steady state compressible multispecies non-reacting flow? inf.vish OpenFOAM Running, Solving & CFD 0 October 1, 2013 02:09
Isothermal fluid flow and the Energy Equation ksq Main CFD Forum 6 September 18, 2013 07:27
fluid flow fundas ram Main CFD Forum 5 June 17, 2000 22:31
