January 8, 2018, 17:33 |
FUN3D Subsonic Inflow Question
Rep Power: 17 |
I am completely new to using FUN3D, and I am trying to run a simple bump in a channel test case to get my sea legs under me. I have specified the pressure subsonic inflow (subsonic_inflow_pt) for the inlet and set the total pressure and temperature ratios based using the isentropic relations for a freestream Mach number of 0.3. However, my solutions show a Mach number of 0.01!
I have looked through NASA/TM-2011-217181, which discusses the inlet and outlet conditions in FUN3D, looking for some additional guidance. One of the test cases made use of the pressure subsonic inflow boundary condition that I am trying to use. The inlet Mach number for this case was about 0.14. The value of pt/pinf that was used in the paper was 1.6, which is no where near the value given by the isentropic relations for the given Mach number. Can someone please explain to me what I am missing/misunderstanding? Thanks! |
fun3d, inlet bc, inlet boundary condition |
Swirl component in inflow BC for 2d axisymmetric flows | vishalsacharya | OpenFOAM Pre-Processing | 2 | November 2, 2018 06:33 |
Density Discontinuity at Inflow Boundary | wididid | OpenFOAM Running, Solving & CFD | 0 | June 22, 2017 10:54 |
mixed inflow/outflow downstream boundary condition question | peob | OpenFOAM Running, Solving & CFD | 3 | February 3, 2017 11:54 |
Eddylicious: a new Python package for turbulent inflow generation | tiam | Main CFD Forum | 0 | October 14, 2016 12:26 |
Inviscid Drag at subsonic, subcritical Mach # | Axel Rohde | Main CFD Forum | 1 | November 19, 2001 13:19 |
