December 29, 2017, 06:28 |
#21 | |
A. Min
Rep Power: 12 |
please introduce me a reference to see this curve (cfl=f(Re_h)) and how to obtain that. Also, what's the meaning of "recovering the constraint due to only the cfl value" ? |
December 29, 2017, 06:50 |
#22 |
Filippo Maria Denaro
Rep Power: 73 |
That is a classical issue in CFD and numerical analysis and requires the use of the von Neumann analysis. Many texbooks give details about that.
An example for a 2D case is shown in https://www.researchgate.net/publica...y-driven_flows |
December 29, 2017, 06:55 |
#23 | |
A. Min
Rep Power: 12 |
December 29, 2017, 23:40 |
#24 | |
Arjun
Rep Power: 34 |
About the Rhie and Chow term, which is difficult to find from books as to what my comment was talking about here is very short hint. Rhie and chow term is inversely propertional to diagonal of momentum matrix. Diagonal of momentum matrix is inversely propertional to time step size. For euler time stepping it would be ( density * volume / delta_T ). So when delta goes to 0, it shall go to infinity and 1/Ap goes to 0. So basically as delta_T reduces the Rhie and Chow term becomes weaker and weaker. After certain value, it could be too small at some parts of simulation that solution can diverge. |
January 9, 2018, 01:36 |
#25 |
A. Min
Rep Power: 12 |
Hi all
I want to solve the flow around the cylinder in viscoelastic fluid. At first I did it for Newtonian fluid in Re= 10 , 40 , 100 and for viscoelastic fluid in Re= 10 , 100 and obtained exact results. But when I change the Re to 40 for viscoelastic fluid, it became diverged! I changed many parameters of solution: urf = from 0.1 to 0.9 --> diverged! corunt Nu. = from 0.1 to 0.9 --> diverged! changing the kind and size of mesh --> diverged! changing the kind and size of mesh --> diverged! increasing the number of solving pressure correction Eqn from 2 to 20 --> diverged! decreasing the min residuals to 1e-8 --> diverged! changing discretization schemes of div terms: Gauss linear (central), Gauss upwind(1st), Gauss upwind(2nd), limitedLinear , QUICK --> diverged! But I have done some ways to solve that: 1- I saw in this page that sb proposed to the other that decrease the residuals to 1e-19 !! I did it and my solution became converged! I can't analyze that! Is it possible? 2- In the other way I increased the number of solving pressure correction Eqn to 20, decreasing the min residuals to 1e-8 3- setting the time step to 0.001 instead of setting Cr=0.3 Now I don't know that my results are reliable or not! Could you please tell me what happend that these solutions are appropriate for solve it? Thanks |
time step size, transient |
[Other] Contribution a new utility: refine wall layer mesh based on yPlus field | lakeat | OpenFOAM Community Contributions | 58 | December 23, 2021 03:36 |
p_rgh initial residual no change with different settings | manuc | OpenFOAM Running, Solving & CFD | 3 | June 26, 2018 16:53 |
pimpleDyMFoam computation randomly stops | babapeti | OpenFOAM Running, Solving & CFD | 5 | January 24, 2018 06:28 |
simpleFoam error - "Floating point exception" | mbcx4jc2 | OpenFOAM Running, Solving & CFD | 12 | August 4, 2015 03:20 |
IcoFoam parallel woes | msrinath80 | OpenFOAM Running, Solving & CFD | 9 | July 22, 2007 03:58 |
