Problem concerning spatial descretization order
Old   December 18, 2017, 01:00
Default Problem concerning spatial descretization order
A-400M
waven is on a distinguished road
Hello.
I have been making 2d euler code for airfoil geometry.
I used Roe scheme for flux treatment.
When i used first order scheme for spatial descretization, calculation was well converged.
But i used second order scheme, error showed up.
Specific symptom is below.
Starting calculation, residual decreased well up to around 0.005 order during several itreations.
But after this iteration, residual increased up to around 0.037 and in the result, error showed up.
I recognized that when residual increase, density on the leading edge become lower than order of density value which is calculated by compressible flow theory.
And then density on the leading edge continue to decrease(=residual continue to increase) and become lower than it of freestream. In the result, error show up.
(Freestream Mach number is 0.7)
When i used first order scheme, this error phenomenon didnt take place.
If you had experience like this or you could guess cause of this error, please give me an advice about what should i check?
When invicid wall boundary treatment is wrong in second order scheme, this phenomenon can happen?
Thanks.
waven is offline   Reply With Quote
Old   December 18, 2017, 08:54
Filippo Maria Denaro
FMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura about
Are you using second order central or upwind discretization? In the former case have you considered that central discretizations for inviscid flow drive to numerical oscillations and finally can produce the solution to blow-up?
You should provide details..
FMDenaro is offline   Reply With Quote
Old   December 18, 2017, 09:23
A-400M
I used the second order upwind as shown in below description.
q(j,k)_left=q(j-1,k)+(q(j,k)-q(j-1,k))/2
q(j,k)_right=q(j+1,k)-(q(j+2,k)-q(j+1,k))/2
Old   December 18, 2017, 09:35
And how do you ensure the upwind criterion? I see only fixed stencils
Old   December 19, 2017, 06:29
A-400M
My descriptin cant be considered as second order upwind? If that, could you let me know the exact description and texts or paper containing the exact description?
Old   December 19, 2017, 06:38
upwind means that you adapt the stencil to the velocity direction
Old   December 19, 2017, 07:19
A-400M
I used cell centered scheme. so i think that my description means the second order upwind at the east face of cell. if you think i was wrong, could you correct my wrong description? you can correct it easily with copy && paste.
Old   December 19, 2017, 12:38
if you consider an FD discretization at the node i, a second order upwind stencil uses i,i-1,i-2 for u>0 and i,i+1,i+2 for u<0.
In a FV discretization, the flux at the face left is discretized over i-2,i-1,i for u>0 and i-1,i,i+1 for u<0, this is at third order of accuracy
Old   December 19, 2017, 21:46
A-400M
you suggested third order scheme for FVM, How is second order scheme described?
and what does the 'u' mean? is it normal velocity at the face?
could you let me know the text related to your description? it is hard to totally understand your description without front and back context.
Old   December 20, 2017, 04:28
u is the convective velocity, have a look to any CFD textbook for the upwind criterion and to the Leonard papers for the third order upwind scheme (QUICK/QUICKEST)
Old   December 20, 2017, 05:38
A. S.
apoorv is on a distinguished road
You will need limiter to limit your reconstruction. In case of shock q(j+1)-q(j) would be discontinuous and lead to error. Refer to Blazek book for further help.
apoorv is offline   Reply With Quote
Old   December 20, 2017, 06:21
naffrancois is on a distinguished road
I agree with apoorv, you may read the book of Blazek:
Computational Fluid Dynamics: Principles and Applications
Especially Chapter 4 where you will find many things you need for structured finite volume scheme of Euler equations.
naffrancois is offline   Reply With Quote
Old   December 20, 2017, 09:40
A-400M
Thanks a lot to apoorv and naffrancois.
I refered to Blazek book and studied MUSCL limiter.
But as far as i know, limiter is not needed in subsonic condition like my case such as Mach number 0.4~0.7. Because shock is not generated.
Limiter can solve this problem?
Old   December 21, 2017, 08:58
A. S.
Yes limiting should help, as it will avoid anyover-shot and undershoot, so as to reduce CFL a bit. Also can you give me detail of solver explicit (how many rk loop) or implicit; what cfl you are running
Old   December 27, 2017, 03:10
A-400M
Thanks a lot apoorv.
CFL is 0.15, time integration method is first order explicit.
When i used limiter, flux from south at the cell above first layer cell on the wall had error. wall boundary cell had no problem but right above cell had error due to error at the south-dir flux.
apoorv, could you give me an advice on what should i check?
inviscid, spatial, wall treatment
First Order to Higher Order Blending Factor NormalVector FLUENT 4 November 13, 2023 08:06
2nd Order Spatial accuracy: Euler Equation on Unstrutured Grid AshwaniAssam Main CFD Forum 1 February 7, 2015 20:06
Lack of understanding? Spatial OF Schemes hxaxtma OpenFOAM Running, Solving & CFD 1 April 30, 2014 08:15
How to compute UDS fourth order gradient Emma66 FLUENT 1 April 27, 2010 06:44
Second order spatial derivatives KRK Main CFD Forum 0 June 26, 2007 00:18
