Flow around an object which contains openings
Old   December 14, 2017, 21:30
Default Flow around an object which contains openings
BabakArash is on a distinguished road
I am planing to model air flow around a barrel which has a couple of openings. Basically air flows around the barrel. Some air can go into the barrel through the openings on the barrel wall facing the inlet air. And, some air can leave the barrel via the openings located on the other side of the barrel facing the outlet.
I would like to use COMSOL, but I do know how to setup my model. Specifically, I do know what sort of boundary conditions I need to use for the openings located on the barrel.
Thanks
BabakArash is offline   Reply With Quote
Old   December 15, 2017, 06:48
BlnPhoenix is on a distinguished road
Originally Posted by BabakArash View Post
Thanks
So you don't want to model the flow inside of the barrel?
BlnPhoenix is offline   Reply With Quote
Old   December 15, 2017, 11:19
Yes, I would like to model air flow around and inside the barrel.
About Some Concepts:Laminar flow, turbulent flow, steady flow and time-dependent flow Jing Main CFD Forum 8 October 5, 2018 18:02
mass flow in is not equal to mass flow out saii CFX 12 March 19, 2018 06:21
Multiphase flow - incorrect velocity on inlet Mike_Tom CFX 6 September 29, 2016 02:27
flow over a cylinder urgent! kevin FLUENT 8 August 11, 2015 14:00
[blockMesh] BlockMeshmergePatchPairs hjasak OpenFOAM Meshing & Mesh Conversion 11 August 15, 2008 08:36
