comparison of discretization scheme
Old   December 14, 2017, 10:43
Default comparison of discretization scheme
A. Min
alimea is on a distinguished road
Hi all
according to Verstig CFD book (and also Patankar) I want to see the effect of the discretization scheme on the results (especially diffusion error in upwind scheme and unboundedness in central scheme). For this purpose I want to solve the equation of T like:
div (phi , T) = 0
(diffusion term should be removed (to see numerical diffusion)) beside the continuity and momentum eqn. in a steady state mood with openfoam(where phi is the flux).
I have gotten the result by Upwind scheme, but unfortunately I can't solve the eqn. with central scheme! my solution become diverge.
Do you know why?
I want to compare the result of two schemes.
Thanks
alimea is offline   Reply With Quote
Old   December 14, 2017, 12:21
Filippo Maria Denaro
FMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura about
Originally Posted by alimea View Post
Hi all
div (phi , T) = 0
Do you know why?
Thanks
This is an exercise for students, just see the book of Peric & Ferziger to study this issue
FMDenaro is offline   Reply With Quote
Old   December 14, 2017, 12:24
Ravindra Shende
Ravindra Shende is on a distinguished road
Central difference scheme is unstable for this equation, that is why your solution is diverging.
You will have to add diffusion artificially in order to stabilize the scheme and get a converged solution.
Ravindra Shende is offline   Reply With Quote
Old   December 14, 2017, 14:27
Martin Hegedus
Martin Hegedus is on a distinguished road
As a general statement, it will be challenging to compare something to central difference. Central difference requires artificial dissipation and the required amount will depend on things like boundary conditions, time marching, how you start the solution (impulse or gradual start), and the form of dissipation itself. Creating a good central difference methodology will allow you to minimize the amount of artificial dissipation, though you may not get to zero. One option is for you to compare things in 1-D. Depending on what you're doing, you may not need artificial viscosity for central difference. For example, I've been able to get away with zero artificial viscosity for some sub-sonic compressible 1-D Euler runs in conservative form. But that is for 1-D only. 2-D and 3-D are different stories.
Martin Hegedus is offline   Reply With Quote
Old   December 15, 2017, 08:09
A. Min
Hi
thanks for your answer
But some body did it :
http://openfoam.blogfa.com/post/112
Old   December 15, 2017, 08:13
A. Min
Thank you Martin
My problem is 1D, steady and pure diffusion. somebody has done it before, but I can't get results!
Old   December 15, 2017, 12:52
Thank you Martin
pure convection or pure diffusion???
Old   December 15, 2017, 19:07
Lucky
Thank you Martin
div (phi , T) = 0 is a pure advection equation. And central differencing does not play happy with this. Pure diffusion on the other hand...
Old   December 16, 2017, 04:34
A. Min
Oh! I typed it wrong! my goal was "pure convection".
Old   December 16, 2017, 05:01
Again, have a look to the book of Peric and Ferziger. Then, to understand the characteristics of a first and second order FD derivative you can just have a look to the local truncation error in physical and wavenumbers space. That is a classical topi for students in CFD.
Old   December 16, 2017, 05:12
A. Min
So, how did he solve that equation?!
It means that we never can solve the pure advection eqn. with central scheme?
A. Min
Ok
thank you
Old   December 17, 2017, 12:10
Martin Hegedus
I'm unable to read the language that page is written in and I'm not very good at Openfoam and its terminology. My question is, are you solving for velocity or is it fixed and what you're solving for is an uncoupled transport equation?
Given what I saw on that page I'm hesitant to say artificial viscosity is required. Granted, as a general statement, it is required.
An underlying assumption for central differencing is that the system is continuous, i.e. (+) and (-) derivatives are equal. Unfortunately, numerically the system is discontinuous, even for a physically continuous system, if there are Taylor series truncation errors.
And I'm under the impression that what is shown on that page may be low order, thus little truncation error. Same as with my 1-D problem, channel flow with area change. In that case Area*rho*U is constant at all points. Thus, if it's in conservative form and solving for steady state implicitly, it's zero order.
Of course there can always be a bug in your code, but I would suggest initializing your run with the exact answer or your upwind scheme solution, and see where things go.
But, again, I have little idea about how Openfoam goes about things, so the solution methodology may introduce higher order noise, in which case bye-bye solution.
Edit: when I wrote that (+) and (-) derivatives are equal, I meant forward and backward derivatives.
Old   December 18, 2017, 14:37
Lucky
What you are trying to do is solve a pure advection equation.
"he" did not solve the pure convection equation. He was solving the full advection-diffusion equation. However, the BC's such that there is no physical diffusion. Notice the BC's in the problem setup. Numerical diffusion stabilizes the problem.
The problem is you are trying to eliminate the diffusion term entirely and solve only the advection part from the governing equations and hence your problem.
Old   December 19, 2017, 02:21
A. Min
The velocity is fixed. I'm solving T as a scalar in div(phi,T)=0 where phi is the mass flux (rho*U).
I wrote a code for this problem:
div(phi , T) = 0
for 2D domain:
Fe.Te - Fw.Tw + Fn.Tn - Fs.Ts = 0
rho, U and A in all of the cells are equal. so:
Fe = Fw = Fn = Fs
and :
Te - Tw + Tn - Ts = 0
if we use "upwind" scheme, we have:
Tp-Tw+Tp-Ts=0
and finally:
Tp = 0.5 * (Ts + Tw)
I got good result for the upwind scheme.
but if I want to use "central" scheme:
(Fe - Fw + Fn - Fs) * Tp = Fw*TW - Fe*TE + Fs*TS - Fn*TN
Tp = (Fw*TW - Fe*TE + Fs*TS - Fn*TN) / (Fe - Fw + Fn - Fs)
Fe = Fw = Fn = Fs
and the denominator of Tp become zero!
Tp = (TW - TE + TS - TN) / (0) !!!!!!
is it correct?
according to what I typed (if it is correct!), we never can use central scheme for pure advection equation. yes?
Thanks
Old   December 19, 2017, 02:36
A. Min
Oh! I think you are right!
some questions:
1- Could you please write the equation that he used? I want to solve this problem
div(phi,T) = ??? (numerical diffusion)
2- As you see in my answer to Martin, I solved this problem with upwind scheme. But I didn't mention Numerical diffusion nor physical diffusion and I could see the numerical diffusion in contour of T. is it wrong? (that I didn't mention Numerical diffusion)
3- I want to find out the concept of "Numerical diffusion" or "false diffusion". I have read Patankar and some other cfd books. but I didn't get that! could you please explain it? or give me a reference to read about it?
Thank you
Old   December 19, 2017, 02:47
Martin Hegedus
The problem needs to be marched forward in time so that the matrix is not singular. What needs to be solved is:
dT/dt + div(T*rho*V) = 0.
Old   December 19, 2017, 05:06
A. Min
but the problem is steady state and when it converges, we have:
Old   December 19, 2017, 05:30
In discrete form, without considering BC.s, you have a system like
A.x=0
so, to avoid to get only the solution x=0 what condition do you need?
Old   December 19, 2017, 06:14
A. Min
A.x=0
I think we need:
det (A) should be non-zero
please tell that your answer is for my which question.
thanks
central, discretization, openfoam, unboundedness, upwind
comparison of discretization scheme alimea OpenFOAM Running, Solving & CFD 0 December 14, 2017 10:42
Temporal discretization Scheme CoEuler vsammartano OpenFOAM Running, Solving & CFD 0 April 12, 2016 08:06
Discretization Scheme dinesh FLUENT 0 August 31, 2013 05:52
Time discretization scheme HaKu Main CFD Forum 1 June 12, 2011 03:06
MARS discretization scheme raymond Siemens 3 February 1, 2002 06:33
