comparison of discretization scheme
Old   December 19, 2017, 12:26
Martin Hegedus
Martin Hegedus is on a distinguished road
When you add dT/dt into the equation you get
(Fe - Fw +1/delta_t + Fn - Fs) * Tp = Fw*TW - Fe*TE + Fs*TS - Fn*TN
If you made delta_t equal to infinity, you recover your equation (which is Newtonian iteration). Unfortunately, as you noticed, the determinant of that is zero.
As a general statement for central differencing one should add dissipation and march forward in time with a reasonable time step, i.e. large but not very large. Non-linear equations can have multiple solutions and marching forward in time (in a reasonable way) helps insure that a solution is found that one can actually get to.
Martin Hegedus is offline   Reply With Quote
Old   December 21, 2017, 11:34
A. Min
alimea is on a distinguished road
if we write your eqn:
in this form:
ap*Tp=aE*TE + aW*TW + aN*TN + aS*TS + b
we can find a negetive coeff for aE and aN for posetive dirrection of flow:
aE = - Fe <0 , aN = - Fn <0
so certainly or solution will be diverged!
I want to conclude that we never can solve pure advection eqn with central scheme.
is it correct?
thanks
alimea is offline   Reply With Quote
Old   December 21, 2017, 12:41
Martin Hegedus
Central schemes are the border between upwind and downwind. I'm not sure of what they are capable of without dissipation.
Old   December 21, 2017, 17:27
Martin Hegedus
Overall, it will depend on your boundary conditions. For example lets look at the determinant of the left hand matrix for Newtonian iteration on a 1-D case with five nodes. Also, lets fix the temperature at the left and the flow moves from left to right.
The LHS matrix for the case where the right hand side temperature (along with left hand side) is fixed is
1 0 0 0 0
-1 0 1 0 0
0 -1 0 1 0
0 0 -1 0 1
0 0 0 0 1
the determinant for that is 0. However, if you had four points, the determinant would be 1. So, that is not robust.
Now lets use first order upwind at the last point
1 0 0 0 0
-1 0 1 0 0
0 -1 0 1 0
0 0 -1 0 1
0 0 0 0-1 1
The determinant of that is 1.
Not sure how well that example transfers over to 2-D, but it's a start and should be straight forward to test.
central, discretization, openfoam, unboundedness, upwind
comparison of discretization scheme alimea OpenFOAM Running, Solving & CFD 0 December 14, 2017 10:42
Temporal discretization Scheme CoEuler vsammartano OpenFOAM Running, Solving & CFD 0 April 12, 2016 08:06
Discretization Scheme dinesh FLUENT 0 August 31, 2013 05:52
Time discretization scheme HaKu Main CFD Forum 1 June 12, 2011 03:06
MARS discretization scheme raymond Siemens 3 February 1, 2002 06:33
