problem with skew faces - how to trace or repair?
Old   December 5, 2017, 11:02
Unhappy problem with skew faces - how to trace or repair?
Gabriela
Gabriela_ro is on a distinguished road
Hello everyone,
I am using OpenFoam 4.1 and I have a lot of very small skew faces (171) after the meshing and i would like to get them back in rhino in order to fix them.
I was able to create a .vtk file and i can open/see them in paraFoam but it is very difficult to follow where they are exactly in order to repair the 3D.
any ideas on this?
- can openFoam create from a vtk or from the skew faces a .stl ?
-is it possible to repair directly in openFoam this surfaces after the meshing and not go back to Rhino or the modelling program?
thank you very much !
Gabriela_ro is offline   Reply With Quote
[Other] Can't Shake Erros: patch type 'patch' not constraint type 'empty' BrendaEM OpenFOAM Meshing & Mesh Conversion 12 April 3, 2022 19:32
decomposePar problem: Cell 0contains face labels out of range vaina74 OpenFOAM Pre-Processing 37 July 20, 2020 06:38
[snappyHexMesh] No layers in a small gap bobburnquist OpenFOAM Meshing & Mesh Conversion 6 August 26, 2015 10:38
[Gmsh] Vertex numbering is dense KateEisenhower OpenFOAM Meshing & Mesh Conversion 7 August 3, 2015 11:49
createPatch Segmentation Fault (CORE DUMPED) sam.ho OpenFOAM Pre-Processing 2 April 21, 2014 03:01
