directionMixed for unidirectional heat flux - conduction.
Old   December 4, 2017, 09:42
Default directionMixed for unidirectional heat flux - conduction.
Marco Bernardes
masb is on a distinguished road
I'm trying to set up a directionMixed (OpenFOAM) internal boundary condition for unidirectional heat flux - anisotropic conduction - in a baffle inside a solid. In one direction the baffle should work as an insulator dT/dx=0. If the temperature gradient is reversed, the baffle (heat flux in the reversed direction), it should work as the original material, as shown below. Any help is welcomed.
Thanks in advance,
Marco.
>x B|zeroGrad x---
----->x A|zeroGrad x---
HOT-->x F|
zeroGrad x--- COLD
----->x F|zeroGrad x---
----->x L|zeroGrad x---
----->x E|zeroGrad x---
<------ B|empty
----- A|empty <---
COLD<-- F|
empty <--- HOT
------ F|empty <---
------ L|empty <---
------ E|empty <-
masb is offline   Reply With Quote
conduction, directionmixed
Conjugate Heat Transfer: Wall Heat Flux at Coupled Walls? MaxHeat FLUENT 4 September 14, 2017 11:44
Sign of Heat Flux at wall Kyung FLUENT 2 February 26, 2016 17:25
Monitor Heat Flux in CFD-Pre cltormar CFX 5 November 20, 2014 12:45
Heat Flux at wall in a conjugate heat transfer problem Chander CFX 2 July 9, 2011 23:22
Heat Flux Wall Boundary Confusion. Joee FLUENT 1 August 21, 2010 13:20
