Use of turbulent intensity and the turbulence length scale?
Old   December 1, 2017, 10:29
Default Use of turbulent intensity and the turbulence length scale?
Gebregziabher
gerie is on a distinguished road
Dear all,
Can somebody help me what is the use of turbulent intensity and the turbulence length scale in turbulence model? why do we put them as input data when we are making turbulence model simulation?Many thanks for your help!
kind regard,
Gerie
gerie is offline   Reply With Quote
Old   December 1, 2017, 14:49
Lucky
Google is your friend.
https://www.cfd-online.com/Wiki/Turbulence_intensity
https://www.cfd-online.com/Wiki/Turb...kinetic_energy
https://en.wikipedia.org/wiki/Turbulence_kinetic_energy
In boundary value problems you specify the governing equations, provide boundary conditions, and then solve for the solution inside the domain,
Hence in addition to pressure, velocity, temperature and so on at boundaries, you also must provide the turbulence (but according to the turbulence variables in your model). If you are using k-epsilon model then you need to specify k and epsilon at boundaries. If you are using k-omega model then you need to specify k and omega at boundaries. etc. Fluent has a feature that allows you to specify instead the turbulence intensity and length scale as a convenience option because people generally have a better feel for intensity and length scale (as opposed to k & epsilon or k & omega).
