November 18, 2017, 04:23 |
3-D wing CFD analysis at low Re
Subhasree
Rep Power: 12 |
I am working on a 3-D subsonic flow wing cfd analysis with the following data: chord length=0.1m half wing span=0.6m Vel-infi=15m/s Re=980,000 I have created a domain size with reference to the tutorial :https://confluence.cornell.edu/displ...ow+Over+a+Wing the boundary conditions are: 1. velocity inlet 2.pressure far-field 3.symmetry 4.pressure outlet I have made a C-mesh with a radius of 2m and back extrusion of 3m. I am getting a mesh size of 40L. with 12 layers of inflation within a thickness of 0.002m. It is a turbulent flow model. It would really be helpful if somebody can guide me on the kind of turbulent model I should opt for to get good results. The required model is having a turbulent intensity =0.05. I have no clue how to calculate turbulent viscosity... I have tried running it with default K-epsilon/S-A model, but the residuals are not converging. nor is the cl monitor. At past i have worked on hypersonic flow Fluent analysis but I have very little Fluent modeling knowledge for low speed flow. It would be really good if somebody can give give some advice as to how I should proceed with the problem statement... Thanks |
November 18, 2017, 07:44 |
Jaesan Yoon
Rep Power: 9 |
how about check y+, then change height of the first cell
November 18, 2017, 09:43 |
Subhasree
Rep Power: 12 |
Thanks for the reply....
I tried calculating the required Y+ value for this model through some online calculator but it was asking for boundary layer thickness(which i don't have) any idea what should be Y+ value for this model? |
CFD Design...The CFD Future | John C. Chien | Main CFD Forum | 20 | November 20, 2015 00:40 |
Cfd to ansys thermal to ansys structural interface | ssixr | ANSYS | 17 | July 31, 2015 16:18 |
CFD Online Celebrates 20 Years Online | jola | Site News & Announcements | 22 | January 31, 2015 01:30 |
[Other] Morphing wing cfd analysis in transition | rekfuh | ANSYS Meshing & Geometry | 0 | June 6, 2012 10:22 |
Where do we go from here? CFD in 2001 | John C. Chien | Main CFD Forum | 36 | January 24, 2001 22:10 |
