how to model polymer solution in CFD
Old   November 16, 2017, 02:23
Question how to model polymer solution in CFD
koral
koraltp is on a distinguished road
Hi everyone,
I would like to analyse flow of polymer solution in an enclosed system.
*System has inlet and outlet.
*Polymer solution is made by mixing 5 g solid in 100 g solvent. So, solid content of solution is %5.
* Polymer solution is non-newtonian liquid,
* Shear thinning occurs at low shear rates,
* Shear rate of the flow is low, flow exit velocity is about 1 m/s.
* Flow temperature is constant at about 20 C.
* At this temperature, more or less, STORAGE elastic shear modulus is larger than LOSS shear modulus. So, the flow has gel-state characteristics.
* At this temperature, viscosity range of solution is 100-250 Pa.s. viscosity changes with shear rate.
How can I model such characteristics of polymer solution in Ansys Fluent like CFD simulation package ? Which material model is applicable ?
Regards
koraltp is offline   Reply With Quote
cfd analysis, non newtonian, polymer, viscoelastic property, viscoelasticfluid
Symmetric vs. complete model solution stability SanFer Main CFD Forum 1 July 18, 2017 11:57
CFD Salary CFD Main CFD Forum 17 January 3, 2017 18:09
Overflow Error in Multiphase Modelling with Two Continuous Fluids ashtonJ CFX 6 August 11, 2014 15:32
Can 2D cfd fluent model solve evaporation harkerz FLUENT 0 May 19, 2013 08:13
Feasiblity of CFD model for Real-Time applications la mimi Main CFD Forum 2 January 28, 2007 05:49
