Initialize Pressure Field in Lattice Boltzmann Method with pressure-based equilibrium |
November 13, 2017, 08:12 |
Julia P.
I am currently learning about Lattice Boltzmann Method for incompressible Navier-Stokes Equation. Specifically speaking about free surface waves from the following paper : click here
It used ILBGK pressure-based equilibrium distribution function by Guo. Basically I understand the overall algorithm of method used in that paper, but I'm confuse how to initialize the distribution function using this model, especially the pressure field which is usually unknown. I want to simulate the propagation of solitary wave over a flat bottom. From the references I've read so far, initial and boundary condition usually state in velocity while the pressure is unknown. I also read consistent initialization by Mei, but it seems it will lots of iteration. Other reference also say that the initial pressure can be found by solving the pressure-poisson equation by Gauss-Seidel Method. I've tried use the latter, but by using different initial pressure at iterative method, I get different result or is it okay to initialize the pressure by constant value? or am I missing some important concept about LBM? Thanks in advanced : Last edited by julia.p; November 13, 2017 at 19:51. |
November 13, 2017, 19:49 |
Arjun
Rep Power: 34 |
if i remember correctly the pressure is result of density and density is equation to sum of probability F functions.
In case of incompressible formulations i am not sure how it would work. |
incompressible fluid, lattice boltzmann method, navier-stokes |
Lattice Boltzmann Method - Forcing term | sgunasekaran | Main CFD Forum | 1 | April 26, 2017 09:02 |
incorrect temperature in pressure based solution | Kian | FLUENT | 1 | July 6, 2009 06:59 |
Periodic BC's for Thermal Lattice Boltzmann Method | anuhar | Main CFD Forum | 0 | May 4, 2009 04:45 |
Hydrostatic pressure in 2-phase flow modeling (CFX4.2) | HB &DS | CFX | 0 | January 9, 2000 14:19 |
Hydrostatic pressure in 2-phase flow modeling (long) | DS & HB | Main CFD Forum | 0 | January 8, 2000 16:00 |
