Are two simulations equivalent if they have the same Grassof and Reynolds?
Old   November 10, 2017, 12:01
Default Are two simulations equivalent if they have the same Grassof and Reynolds?
Hector Redal
HectorRedal is on a distinguished road
I would like to know if two simulations that have the same Reynolds and Grassof number are thermally equivalent?
I am trying to simulate the problem described in the following article:
http://heattransfer.asmedigitalcolle...icleid=1438948
I am supposing air with Pr = 0.71.
When I double the viscosity, doubling the inlet velocity (keeping reynolds number), and doubling the temperature difference in the formula for calculating the Grashof number, the results I am obtaining are different.
I have always understood that non-dimensional number allow comparison between different simulations/experiments that show same behaviour.
May I am missing something?
As thermal coefficient expansion (beta) for the Grashof number I am using 1/T, being T the low temperature in the problem.
Should I use any other value for the temperature (i.e., the high temperature)? The middle temperature in the range?
Any comment is welcome.
Best regards,
Hector.
HectorRedal is offline   Reply With Quote
Old   November 10, 2017, 12:10
Filippo Maria Denaro
FMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura about
You can easily answer by looking at the governing equations in non-dimensional form. If you have the same non dimensional parameters the two non-dimensional solutions must be the same.
FMDenaro is offline   Reply With Quote
Old   November 10, 2017, 20:26
Hector Redal
This was also my understanding, but what I am observing is not this.
The non-dimensional solution differ by almost 5%.
Old   November 11, 2017, 04:27
There is a difference in the two simulation, maybe different iteration accuracy
Old   November 13, 2017, 12:32
Hector Redal
If I run a simulation without solving the energy equation, the difference between two solution having the same non-dimensional numbers (but using different values for velocity, or density, or viscosity, etc.) is almost zero.
I only observe this discrepancy when trying to solve a problem with energy equation coupled. The difference between both solutions is more ore less 5%. No more.
For me, it's more than can be justified by the accuracy iteration. Maybe I am wrong.
