Pressure boundary condition (Both inlet and outlet together)
Old   November 7, 2017, 08:15
Default Pressure boundary condition (Both inlet and outlet together)
ehsan
e_cfd is on a distinguished road
Dear friends,
I am a little bit confused by pressure boundary conditions and really appreciate if anyone can help me with this. In FLUENT User's Guide (Open Chanel Flow 23.3.9 section), it is mentioned that using Pressure inlet and Pressure outlet together is ok, while as I know the problem is not mathematically well-posed and is overdetermined when we use SIMPLE algorithm.
What if we use Coupled algorithm instead of SIMPLE?.
The other question is that when we face a problem that pressure boundary conditions (at inlet and outlet) are the correct ones. For instance, if we have an unsteady pipe flow with deposition what would be a proper BC for inlet? ( due to deposition we would face an increasing flow blockage inside the pipe and increasing pressure drop leads to the mass flow reduction). What would be the best BC for such a problem?
Thanks,
Best regards,
e_cfd is offline   Reply With Quote
Wind turbine simulation Saturn CFX 60 July 17, 2024 06:45
Appropriate pressure boundary condition in incompressible flow lonelywing OpenFOAM Running, Solving & CFD 21 June 6, 2022 10:44
pressure outlet boundary condition hamid_reza Fluent Multiphase 1 September 9, 2014 14:43
Question about heat transfer coefficient setting for CFX Anna Tian CFX 1 June 16, 2013 07:28
Water subcooled boiling Attesz CFX 7 January 5, 2013 04:32
