November 6, 2017, 11:44 |
Reynolds number for poiseuille flow
Alok
For fluid flow between two fixed plates when the ratio of width to distance between plates is around 200, how can the Reynolds number be calculated? Should the characteristic length be calculated by 4A/P or should the distance between the plates be directly used?
November 6, 2017, 12:20 |
#2 | |
Filippo Maria Denaro
Rep Power: 73 |
November 7, 2017, 07:03 |
Alok
With air at around 2 deg C, flowing with a mean velocity of 1 m/s, and a geometry of cross-section of 2.000 m x 0.010 m, the Reynolds number becomes:
1. ~700 for 0.01 as the characteristic length 2. ~1400 for 4A/P as the characteristic length Can you assure the validity of your answer? |
November 7, 2017, 11:20 |
Rep Power: 73 |
There is no one unique Reynolds value, in principle you could choice any lenght you want. But if you want to characterize the non dimensional parameters to assess the relevance of the ratio between convective and diffusive fluxes, the lenght has to be chosen properly.
November 7, 2017, 12:57 |
#5 | |
Alex
Rep Power: 49 |
Both are possible and valid definitions for a Reynolds number of your flow case. However, defining the hydraulic diameter as the characteristic length of your flow problem for an aspect ratio of 200 is quite a stretch. Think of it this way: making the channel twice as wide (2m -> 4m) will not have a significant effect on the nature of the flow. Increasing the height instead by a factor of 2 (0.01m -> 0.02m) can make the difference between a laminar and a turbulent flow. So in your case the height would clearly be a better choice for the characteristic length. |
characteristic length, poiseuille flow, reynolds number |
decomposePar problem: Cell 0contains face labels out of range | vaina74 | OpenFOAM Pre-Processing | 37 | July 20, 2020 06:38 |
[snappyHexMesh] Error snappyhexmesh - Multiple outside loops | avinashjagdale | OpenFOAM Meshing & Mesh Conversion | 53 | March 8, 2019 10:42 |
High Reynold's Number flow through diverging channel | arka14 | OpenFOAM Running, Solving & CFD | 0 | July 5, 2017 08:06 |
AMI interDyMFoam for mixer | danny123 | OpenFOAM Running, Solving & CFD | 4 | June 19, 2013 05:49 |
High Reynolds Number Incompressible Flow | Nick Lavery | Main CFD Forum | 3 | February 19, 2002 16:47 |
