JScript Command used for Suppressing Joint feature in DesignModeler ?
Old   October 28, 2017, 09:54
Default JScript Command used for Suppressing Joint feature in DesignModeler ?
Tyne and Wear
Nawfal is on a distinguished road
Hi Members,
Please, can you tell me what is the appropriate JScript Command specified for suppression of joint feature in DesignModeler, which is pertaining agToolsHandler function as I found it in the jscript file of API scripts called (agEventHandler.js). Sorry, I am newcomer to this forum and I appreciate any help from any member please because I have spent long time managing to find the suitable jscript code to automate this feature.
Thank you too much
Nawfal is offline   Reply With Quote
Old   September 1, 2019, 16:15
Smile using API command to control the Geometry in DesignModeler
Tyne and Wear
Here is the section used to modify the geometry in DesignModeler to perform the structural optimization in ANSYS
//////// This Section is Intended for Hiding "Surrounding Environment" Medium //////////
var AAA = "Surrounding Environment";
HidingBody(AAA);
//////// This Section is Intended for Deleting the Old Joint ///////
var BBB = "Joint1";
DeletingFeature(BBB);
/// This Section is Designed for Manipulating Discrete ///
//////// Set of Design Variables of the Problem //////////
var A1 = "IBeam_A";
for (var n = 1; n <= 4; n++) {
if (n==1) { var B1 = "W3"; var C1 = 0.304800; UpdatingFeatParameter(A1, B1, C1); }
else if (n==2) { var B1 = "W1"; var B2 = "W2"; var C1 = 0.128981; UpdatingFeatParameter(A1, B1, C1); UpdatingFeatParameter(A1, B2, C1);}
else if (n==3) { var B1 = "t3"; var C1 = 0.010871; UpdatingFeatParameter(A1, B1, C1); }
else if (n==4) { var B1 = "t1"; var B2 = "t2"; var C1 = 0.013818; UpdatingFeatParameter(A1, B1, C1); UpdatingFeatParameter(A1, B2, C1);}
var A1 = "IBeam_B";
if (n==1) { var B1 = "W3"; var C1 = 0.457200; UpdatingFeatParameter(A1, B1, C1); }
else if (n==2) { var B1 = "W1"; var B2 = "W2"; var C1 = 0.152425; UpdatingFeatParameter(A1, B1, C1); UpdatingFeatParameter(A1, B2, C1);}
else if (n==3) { var B1 = "t3"; var C1 = 0.011709; UpdatingFeatParameter(A1, B1, C1); }
else if (n==4) { var B1 = "t1"; var B2 = "t2"; var C1 = 0.017551; UpdatingFeatParameter(A1, B1, C1); UpdatingFeatParameter(A1, B2, C1);}
var A1 = "IBeam_C";
if (n==1) { var B1 = "W3"; var C1 = 0.609600; UpdatingFeatParameter(A1, B1, C1); }
else if (n==2) { var B1 = "W1"; var B2 = "W2"; var C1 = 0.180975; UpdatingFeatParameter(A1, B1, C1); UpdatingFeatParameter(A1, B2, C1);}
else if (n==3) { var B1 = "t3"; var C1 = 0.015875; UpdatingFeatParameter(A1, B1, C1); }
else if (n==4) { var B1 = "t1"; var B2 = "t2"; var C1 = 0.022098; UpdatingFeatParameter(A1, B1, C1); UpdatingFeatParameter(A1, B2, C1);}
var A1 = "IBeam_D";
if (n==1) { var B1 = "W3"; var C1 = 0.622300; UpdatingFeatParameter(A1, B1, C1); }
else if (n==2) { var B1 = "W1"; var B2 = "W2"; var C1 = 0.204470; UpdatingFeatParameter(A1, B1, C1); UpdatingFeatParameter(A1, B2, C1);}
else if (n==3) { var B1 = "t3"; var C1 = 0.020320; UpdatingFeatParameter(A1, B1, C1); }
else if (n==4) { var B1 = "t1"; var B2 = "t2"; var C1 = 0.027686; UpdatingFeatParameter(A1, B1, C1); UpdatingFeatParameter(A1, B2, C1);}
var A1 = "IBeam_E";
if (n==1) { var B1 = "W3"; var C1 = 0.381000; UpdatingFeatParameter(A1, B1, C1); }
else if (n==2) { var B1 = "W1"; var B2 = "W2"; var C1 = 0.139725; UpdatingFeatParameter(A1, B1, C1); UpdatingFeatParameter(A1, B2, C1);}
else if (n==3) { var B1 = "t3"; var C1 = 0.010439; UpdatingFeatParameter(A1, B1, C1); }
else if (n==4) { var B1 = "t1"; var B2 = "t2"; var C1 = 0.015799; UpdatingFeatParameter(A1, B1, C1); UpdatingFeatParameter(A1, B2, C1);}
var A1 = "IBeam_F";
if (n==1) { var B1 = "W3"; var C1 = 0.508000; UpdatingFeatParameter(A1, B1, C1); }
else if (n==2) { var B1 = "W1"; var B2 = "W2"; var C1 = 0.158877; UpdatingFeatParameter(A1, B1, C1); UpdatingFeatParameter(A1, B2, C1);}
else if (n==3) { var B1 = "t3"; var C1 = 0.012827; UpdatingFeatParameter(A1, B1, C1); }
else if (n==4) { var B1 = "t1"; var B2 = "t2"; var C1 = 0.020193; UpdatingFeatParameter(A1, B1, C1); UpdatingFeatParameter(A1, B2, C1);}
var A1 = "Channel_A";
if (n==1) { var B1 = "W3"; var C1 = 0.203200; UpdatingFeatParameter(A1, B1, C1); }
else if (n==2) { var B1 = "W1"; var B2 = "W2"; var C1 = 0.064186; UpdatingFeatParameter(A1, B1, C1); UpdatingFeatParameter(A1, B2, C1);}
else if (n==3) { var B1 = "t3"; var C1 = 0.012370; UpdatingFeatParameter(A1, B1, C1); }
else if (n==4) { var B1 = "t1"; var B2 = "t2"; var C1 = 0.009906; UpdatingFeatParameter(A1, B1, C1); UpdatingFeatParameter(A1, B2, C1);}
var A1 = "Channel_B";
var A1 = "Channel_C";
if (n==1) { var B1 = "W3"; var C1 = 0.152400; UpdatingFeatParameter(A1, B1, C1); }
else if (n==2) { var B1 = "W1"; var B2 = "W2"; var C1 = 0.048768; UpdatingFeatParameter(A1, B1, C1); UpdatingFeatParameter(A1, B2, C1);}
else if (n==3) { var B1 = "t3"; var C1 = 0.005080; UpdatingFeatParameter(A1, B1, C1); }
else if (n==4) { var B1 = "t1"; var B2 = "t2"; var C1 = 0.008712; UpdatingFeatParameter(A1, B1, C1); UpdatingFeatParameter(A1, B2, C1);}
var A1 = "Channel_D";
else if (n==2) { var B1 = "W1"; var B2 = "W2"; var C1 = 0.086360; UpdatingFeatParameter(A1, B1, C1); UpdatingFeatParameter(A1, B2, C1);}
else if (n==3) { var B1 = "t3"; var C1 = 0.010160; UpdatingFeatParameter(A1, B1, C1); }
else if (n==4) { var B1 = "t1"; var B2 = "t2"; var C1 = 0.016510; UpdatingFeatParameter(A1, B1, C1); UpdatingFeatParameter(A1, B2, C1);}
var A1 = "Channel_E";
if (n==1) { var B1 = "W3"; var C1 = 0.177800; UpdatingFeatParameter(A1, B1, C1); }
else if (n==2) { var B1 = "W1"; var B2 = "W2"; var C1 = 0.055728; UpdatingFeatParameter(A1, B1, C1); UpdatingFeatParameter(A1, B2, C1);}
else if (n==3) { var B1 = "t3"; var C1 = 0.007976; UpdatingFeatParameter(A1, B1, C1); }
else if (n==4) { var B1 = "t1"; var B2 = "t2"; var C1 = 0.009296; UpdatingFeatParameter(A1, B1, C1); UpdatingFeatParameter(A1, B2, C1);}
var A1 = "Sketch10";
var B1 = "V17";
var C1 = 0.861538;
var A1 = "Crown Gusset";
var B1 = "Thickness (>=0)";
var C1 = 0.015077;
var A1 = "Crown Outer Ring";
var C1 = 0.037500;
var A1 = "Crown Inner Ring";
var C1 = 0.028500;
// This Section is Designed for Manipulating Continuous //
var A1 = "Sketch6";
var B1 = "R6";
var C1 = 48.679806;
var B1 = "H16";
var C1 = 1.000000;
var A1 = "Sketch11";
var B1 = "L18";
var C1 = 0.488190;
var A1 = "Sketch7";
var B1 = "H" + 68;
var C1 = 0.291067;
var A1 = "Sketch7";
var B1 = "H" + 69;
var C1 = 0.345823;
var A1 = "Sketch7";
var B1 = "H" + 70;
var C1 = 0.646875;
var A1 = "Sketch7";
var B1 = "H" + 71;
var C1 = 3.387683;
var A1 = "Sketch7";
var B1 = "H" + 72;
var C1 = 4.545067;
var A1 = "Sketch7";
var B1 = "H" + 73;
var C1 = 1.206536;
var A1 = "Sketch7";
var B1 = "H" + 74;
var C1 = 3.022823;
var A1 = "Sketch7";
var B1 = "H" + 75;
var C1 = 1.864147;
var A1 = "Sketch7";
var B1 = "H" + 76;
var C1 = 4.349677;
var A1 = "Sketch7";
var B1 = "H" + 77;
var C1 = 1.326099;
var A1 = "Sketch7";
var B1 = "H" + 78;
var C1 = 2.424696;
var AAA = "Joint";
var BBB = "Joint1";
var CCC = "Target Geometries";
CreatingNewJoint(AAA, BBB, CCC);
ag.m.ShowAllBodies(); // To Show All Bodies in the Graphics
//ag.m.ShowAllFaces(); // To Show All Faces in the Graphics
ag.agApplet.GuiModeler.ZoomFit();
designmodeler, editing, joint, jscript
[snappyHexMesh] Error snappyhexmesh - Multiple outside loops avinashjagdale OpenFOAM Meshing & Mesh Conversion 53 March 8, 2019 10:42
[DesignModeler] Jscript command for Fill in DesignModeler kar.coep ANSYS Meshing & Geometry 8 April 30, 2015 19:48
