Need help with newtons method
Old   October 24, 2017, 20:12
Default Need help with newtons method
frank
Fahraynk is on a distinguished road
I have a system which I solved with newtons iteration, and I have to add an additional unknown to the system. The system is the following :
f'''+\frac{m+1}{2} ff''+m(1-(f')^2)=0
I broke it up into a system of 3 equations:
F_p-f'=0
F_{pp}-F_p''=0
F_{pp}'+\frac{m+1}{2}FF_{pp}+m(1-F_p^2)=0
m is a constant; I set manually set m.
Unknowns are f, Fp, Fpp.
The equations are approximated with taylor's approximations, and G(x)=0 is the sum of these 3 equations at 1000 grid points + 3 initial conditions.
Currently, X=[f_1...F_{1000},F_{p1}...F_{p1000},F_{pp1}...F_{pp1000}], and I use newtons iteration to solve for X such that G(X)=0
This problem I am trying to solve is this, I am given this information :
H=\frac{\delta}{\theta}
\delta=\int_0^\infty(1-F_p) dy
\theta=\int_0^\infty(1-F_p)F_p dy
I am told that I have to take a given H, and use newtons iteration to find m, the constant which I was setting manually before.
I want to know, if I change X to X=[F,F_p,F_{pp},m] and then add to G(x), H-\frac{\delta}{\theta}=H-\frac{\int_0^\infty(1-F_p)}{\int_0^\infty(1-F_p)F_p} ,will this be enough for newtons method to solve for m? Or do I have to do something else?
Fahraynk is offline   Reply With Quote
Lattice Boltzmann method vs Finite Element Method and Finite Volume Method solemnpriest Main CFD Forum 3 August 12, 2013 12:00
Help about the preconditioner in gmres method Dan Gao Main CFD Forum 3 July 5, 2008 02:18
About flowfield-dependent variation(FDV) method? Jinwon Main CFD Forum 1 December 4, 2007 22:13
Info on method of lines approach charlie ryan Main CFD Forum 2 August 9, 2007 12:06
tidal flow simulation using finite volume method Jason Qiu Main CFD Forum 0 October 20, 2002 03:34
