Test cases for 2d compressible viscous flows
Old   October 24, 2017, 16:29
Default Test cases for 2d compressible viscous flows
Aranya Dan
crazyshock is on a distinguished road
I have written a code for solving unsteady 2d compressible viscous flows with WENO5 schemes and looking for simple test cases. I have checked the inviscid case solving 2d Reimann problems and have acceptable results. Lid-driven cavity isn't a good option as the benchmarks available are for incompressible flows. I dont want to solve over 0012 airfoil as setting up the grid itself would take a lot of time. Please mention some test cases along with reference papers to test run my code.
crazyshock is offline   Reply With Quote
Old   October 25, 2017, 09:54
Praveen. C
praveen is on a distinguished road
Some problems you can try with a weno code on Cartesian grids
These two have smooth solutions but good to test code since they have exact solution:
Plane Poiseuille (density is constant)
Plane couette (constant pressure, variable density)
Shock-boundary layer interaction: google this
A Validated Nonlinear Kelvin-Helmholtz Benchmark for Numerical Hydrodynamics
https://arxiv.org/abs/1509.03630
A vortex roll-up test, incompressible but good to test weno scheme since vorticity develops sharp gradients, you can try this at low mach number.
Jian-Guo Liu and Chi-Wang Shu, A High-Order Discontinuous Galerkin Method for 2D Incompressible Flows, Journal of Computational Physics 160(2):577-596, August 1999, DOI: 10.1006/jcph.2000.6475
praveen is offline   Reply With Quote
Old   October 25, 2017, 10:26
Joern Beilke
JBeilke is on a distinguished road
There are some testcases on:
https://github.com/unicfdlab?tab=repositories
(pisoCentral, QGD, hybridSolvers)
Some of the cases are described here:
https://www.researchgate.net/publica..._viscous_flows
JBeilke is offline   Reply With Quote
test cases, validation
Test cases for incompressible rotating flow. akoodlyr SU2 2 September 29, 2017 12:41
Using pressure based solver for compressible flows aamer Main CFD Forum 2 June 15, 2011 13:45
critical error during installation of openfoam Fabio88 OpenFOAM Installation 21 June 2, 2010 04:01
Standard CFD test cases? Damon Qualski Main CFD Forum 1 April 10, 2003 15:10
Compressible Viscous Code vaidation test cases? Mohammad Kermani Main CFD Forum 2 November 11, 1999 15:22
