Setup of impinging jet model
Old   October 24, 2017, 06:35
Default Setup of impinging jet model
ritwik_101 is on a distinguished road
I am trying make the setup of the impinging jet model : axisymmetric 2D impinging jet on a flat plate. How should the meshing be as I think making finer mesh near the wall of impingement should be necessary, is there anywhere else where I should be focussing for making the mesh finer ?
Also I am not able to decide which turbulence modelling to follow for the impinging jet. Please help and thanks in advance !!!
ritwik_101 is offline   Reply With Quote
Old   October 30, 2017, 04:49
david
davidwilcox is on a distinguished road
You should consider the hiemenz flow with respect to the grid requirement especially in impingement area along the stagnation line. It has to be zero along the stagnation line by theory. As far as turbulence modelling is concerned, avoid using the k-epsilon as it is well-known for its stagnation flow anomalies ( the excessive generation of turbulence and negative normal stresses). Look up Durbin's model or you could try the SST k omega .
davidwilcox is offline   Reply With Quote
Overflow Error in Multiphase Modelling with Two Continuous Fluids ashtonJ CFX 6 August 11, 2014 15:32
impinging jet natesan Siemens 1 February 25, 2005 04:16
Turbulence model for supersonic jet Danny Tandra Main CFD Forum 3 August 24, 2001 05:10
Impinging Jet Modeling Problem Anindya FLUENT 1 August 11, 2001 04:16
Impinging Jet Modeling Problem Anindya Siemens 0 August 10, 2001 00:06
