Too high pressure force ?
Old   March 14, 2000, 06:51
Default Too high pressure force ?
Tim Franke
Hello everybody,
I'm doing a simulation on a very slim body similar to an airfoil. I have problems in getting the drag right. There's no separation at the body. If I split up the drag force into force by shear stress and force by pressure the pressure force is exactly the wrong offset from the experimental value. I have thought, that for a slim body the drag is only due to wall shear stress, so why do I have an additional pressure force. I have used the standard k-eps model.
Thanks for your comments.
Tim
Old   March 15, 2000, 00:36
Default Re: Too high pressure force ?
Bob Anderson
Maybe you could try working on the Euler calculation first, to see if you are getting the expected result. Then work your way back up to the full blown turbulent viscous case.
Bob
"Pressure Inlet" Boundary Setup Wijaya FLUENT 15 May 18, 2016 11:08
Pressure Force Integral Steve R FLUENT 1 February 4, 2013 14:07
how does Fluent calculate the pressure and viscous force ? e30.lsb FLUENT 7 June 27, 2011 22:31
Force vs. pressure integration CFX-post realanony87 CFX 0 May 30, 2009 17:37
How to get the pressure force on a surface? Jimmy Siemens 5 January 25, 2008 06:54
