Diffuser analysis - Compressible flow
Old   October 6, 2017, 17:00
Post Diffuser analysis - Compressible flow
Dameon Derk
Doritz is on a distinguished road
My diffuser is something like as shown in this image. http://turbomachinery.asmedigitalcol...11007_f002.png
I have the impeller exit velocity components and total temperature at diffuserr inlet , but I seer compressible flows, I cannot apply velocity inlet condition. How should I go about with the boundary conditions of this problem? I also don't have the diffuser exit conditions and I cannot apply outflow boundary as it is not compatible with compressible flows.
Any help will be appreciated.
Thankks a lot
Doritz is offline   Reply With Quote
Old   October 10, 2017, 19:48
Dameon Derk
I am still looking for solutions..
Old   October 24, 2018, 11:08
MWRS
waseeqsiddiqui is on a distinguished road
Me too. :/
Do you have total pressure and Mach at inlet?
If so, I think applying Pressure inlet and mass fow rate outlet is a good choice. It wont have any compatibility issues.
waseeqsiddiqui is offline   Reply With Quote
Old   October 26, 2018, 11:34
Lee Strobel
Time4Tea is on a distinguished road
Hi, I think you need to clarify more about what you are trying to do:
1) What are your inputs?
2) What are you trying to calculate?
3) What software are you using?
Time4Tea is offline   Reply With Quote
Old   October 26, 2018, 12:14
MWRS
Hello Time4Tea. I am using Ansys Fluent 18. I'm provided for a duct the total pressure, static pressure, and inlet mach.
The Mach is subsonic and compressible, above 0.3 Mach hence density is set to ideal gas.
The domain is a diffuser with inlet, outlet and wall. I want to calculate outlet total pressure or pressure recovery. Please tell me what boundary conditions should I use for inlet and outlet? How do I specify the above mentioned known values in these boundaries?
Last edited by waseeqsiddiqui; November 21, 2018 at 04:13. Reason: adding software name too
Old   January 9, 2019, 11:55
MWRS
pls help.....
centrifugal compressor, compressible flows, diffuser, fluent
compressible vs incompressible flow Nick R Main CFD Forum 1 March 15, 2017 12:29
Compressible flow in vacuum condition aerocfd FLUENT 0 December 2, 2015 20:48
How to Check Mass Flow Rate in 2D Analysis - CFX nasir FLUENT 0 October 9, 2011 03:52
Compressible flow analysis Sonu Siemens 3 December 5, 2007 08:25
fluid flow fundas ram Main CFD Forum 5 June 17, 2000 22:31
