cgns & hdf5
Old   September 25, 2017, 10:45
Default cgns & hdf5
kostas
pankos is on a distinguished road
I encounter a problem regarding the reading of hdf5-based cgns files using
mid-level library functions.
In particular the "cg_coord_read" as well as the "cg_close" functions does not work properly and therefore I can nott read the data from the nodes. As far as I saw something happens in providing and managinf node ids in ADFH.c and hdf5 libraries.
As for classic adf-based cgns files, there is nothing wrong and all works fine.
Also, the versions of cgnslib and hdf5 is 3.13 and 1.8.12.
Have you ever encountered such problems and how you solve them?
thanks
pankos is offline   Reply With Quote
[Gmsh] Cgns support for gmsh robyTKD OpenFOAM Meshing & Mesh Conversion 1 July 13, 2016 12:27
HDF5 or ADF? nba1942 Pointwise & Gridgen 2 July 16, 2015 13:19
How could I use CGNS with HDF5 codezy SU2 1 April 8, 2014 03:26
writing link between two CGNS files t.teschner Main CFD Forum 1 February 4, 2014 11:26
parallel support with CGNS format not yet implemented kirkrich SU2 3 January 18, 2013 16:39
