September 25, 2017, 05:51 |
implicit crank nicolsol (burger equations)
Marco Ghiani
Rep Power: 15 |
Hi everybody ! I'm trying to understand the implicit algorithm used here http://hmf.enseeiht.fr/travaux/CD000.../reportbid.htm , In Particolar what's the physicals meaning of the coefficient LAMBDA and ALPHA ?? in the calculation of the d array ? a sort of solution relazation or what ever ?
which range of values should have ? thanks in advance |
September 25, 2017, 06:45 |
#2 | |
Filippo Maria Denaro
Rep Power: 73 |
If you work only with the convective and diffusive terms, then alpha=lambda=0 |
September 25, 2017, 09:51 |
Marco Ghiani
Rep Power: 15 |
Ok !! so I'm try to implement a implicit method (taking ideas from this implicit resolution .. ) but using matrices .. in this way I can taking account of the time marcing and obtain a matrix containg all the solution !
unfortunally I'm made a mistake .. I cannot find where ! could some body give a look to my simple code ?? Code:
MODULE PARAM IMPLICIT NONE INTEGER , PARAMETER :: DP = KIND(1.d0) INTEGER , PARAMETER :: SP = KIND(1.0) END MODULE MODULE BURGER_2I USE PARAM IMPLICIT NONE !------------------- REAL(DP), PARAMETER :: x0 =0.D0,xF =1.D0,t0=0.D0,tF=1.D0 REAL(DP), PARAMETER :: dx = 0.005!0.005 REAL(DP), PARAMETER :: dt = 0.01!0.01 REAL(DP), PARAMETER :: nu = 10E-3 INTEGER , PARAMETER :: N = CEILING((XF-X0)/DX) INTEGER , PARAMETER :: M = CEILING((tF-t0)/DT) REAL(DP), DIMENSION(N+1,M+1) :: a, b, c, d , c2, d2 REAL(DP), PARAMETER :: R= nu*dt/dx**2 , K= dt/(2*dx) REAL(DP), PARAMETER :: LAMBDA= 0.d0 , ALPHA= 0.d0 INTEGER , PARAMETER :: cl = 1 REAL(DP), PARAMETER :: pi = 3.14159265358979323846 REAL(DP), DIMENSION(N+1) :: aa, bb, cc, dd , cc2, dd2, u1 CONTAINS !------------------------------------------------------------------------ SUBROUTINE BURGER_IMPLICIT (x,t,u) USE PARAM IMPLICIT NONE REAL(DP) , DIMENSION(N+1) :: x ,u1 REAL(DP) , DIMENSION(M+1) :: t REAL(DP) :: tt REAL(DP) , DIMENSION(N+1,M+1) :: u INTEGER :: i,j, stat INTEGER :: tM a = 0.d0 b = 0.d0 c = 0.d0 d = 0.d0 x(1:N+1) = (/( (x0 + dx*(i-1)), i=1,N+1) /) t(1:M+1) = (/( (t0 + dt*(j-1)), j=1,M+1) /) U(1:N+1,1:M+1) = RESHAPE((/ ((( sin(2*pi*(i-1))/N ), i=1,N+1),j=1,M+1) /),(/N+1,M+1/)) !------------------- Inizializing using IMPLICIT-DO loop a(2:N+1,1:M+1) = RESHAPE((/ (((-0.25*dt/dx*U(i-1,j)), i=2,N+1),j=1,M+1) /),(/N,M+1/)) b(1:N+1,1:M+1) = 1 + R c(1:N ,1:M+1) = RESHAPE((/ ((( 0.25*dt/dx*U(i+1,j)), i=1,N) ,j=1,M+1) /),(/N,M+1/)) d(1,1:M+1) = (/((1-R)*U(1,j) + 0.5*R*U(2,j), j=1,M+1)/) d(N+1,1:M+1) = (/( 0.5*R*u(N,j) + (1-R)* u(N+1,j), j=1,M+1 )/) d(2:N,1:M+1) = RESHAPE((/ (((0.5*R*u(i-1,j)+ & & (1-R)*u(i,j)*0.5*R*u(i+1,j)+dt*(LAMBDA*u(i,j)+ALPHA*u(i,j)**3)) ,i=2,N),j=1,M+1)/),(/N-1,M+1/)) ! DO j=1,M+1 ! DO i=2,N ! d(i,j) = 0.5*R*u(i-1,j)+(1-R)*u(i,j)*0.5*R*u(i+1,j)+dt*(LAMBDA*u(i,j)+ALPHA*u(i,j)**3) ! END DO ! END DO !----------------------------------------------------------------------- !----------- THOMAS ALGORITHM !----------------------------------------------------------------------- c2(1,1:M+1) = (/ (c(1,j)/b(1,j), j=1,M+1) /) d2(1,1:M+1) = (/ (d(1,j)/b(1,j), j=1,M+1) /) c2(2:N+1,1:M+1) = RESHAPE((/(( c(i,j)/(b(i,j)-a(i,j)*c2(i-1,j)) , i=2,N+1), j=1,M+1)/),(/N,M+1/)) d2(2:N+1,1:M+1) = RESHAPE((/(( (d(i,j)-a(i,j)*d2(i-1,j))/(b(i,j)-a(i,j)*c2(i-1,j)),i=2,N+1) , & & j=1,M+1)/),(/N,M+1/)) !----------------------------------------------------------------------- !------------ BACKWARD BIDIAGONAL SISTEM RESOLUTION ~ ~ u(n+1,1:M+1) = dd2(n+1) !Print*, shape(U) , shape(d2) !U(1:N+1,1:M+1) = (/( )/) DO j=1,M+1 DO i=1,N u(N+1-i , j) = d2(N+1-i,j) - u(N-i+2,j) * c2(n+1-i,j) END DO END DO OPEN(UNIT=10,FILE='implicit_burger.dat',STATUS='UNKNOWN',IOSTAT=stat) IF (stat .NE. 0) THEN WRITE(6,'(A)') 'Error opening file ''implicit_burger.dat''!, EXIT 1' STOP ELSE DO j=1,M+1 WRITE (10,FMT='(3E20.8)') (x(i) , t(j) , u(i,j), i=1,N+1) WRITE (10,*) ! WRITE (6,FMT='(50("-"))') END DO END IF CLOSE(10) OPEN(20,file='i_burger.dat',STATUS='UNKNOWN',IOSTAT=stat) IF (STAT .NE. 0) THEN WRITE(6,FMT='(A)')'Error opening File ''bur1.dat'' (EXIT1)' STOP ELSE !DO j=1,M+1 !WRITE(10,FMT='(3F20.5)') (x(i), t(j) ,u(i,j), i=1,N+1) !((u(i,j) , i=1,N+1), J=1,M+1) WRITE(20,*) WRITE(20,FMT='(2E20.8)') (x(i), u1(i), i=1,N) !((u(i,j) , i=1,N+1), J=1,M+1) !WRITE(6,'(50("-"))') !END DO END IF CLOSE(20) RETURN END SUBROUTINE !------------------------------------------------------------------------ END MODULE Code:
PROGRAM main USE BURGER_2I IMPLICIT NONE REAL(DP) , DIMENSION (N+1) :: xx REAL(DP) , DIMENSION (M+1) :: tt REAL(DP) , DIMENSION (n+1,M+1) :: UU CALL BURGER_IMPLICIT(xx,tt,UU) !CALL STOP END |
September 25, 2017, 12:09 |
Rep Power: 73 |
What error do you get?
September 25, 2017, 12:18 |
Marco Ghiani
Rep Power: 15 |
the compilation and link goes always successfully , but the result are surreal, you can try the code for better understanding
September 25, 2017, 12:28 |
#6 | |
Rep Power: 73 |
At present I cannot compile it, "surreal" means nothing to understand the issue. Are you encountering a numerical instability? Have you first completed the code for the simple FTUS scheme on periodic condition? That is the first step to check first the code structure and then implement other schemes |
September 25, 2017, 13:10 |
Crank-Nicholson
Selig
Rep Power: 11 |
Just an observation: I would not use Crank-Nicholson for the burgers equation unless you perform some operator splitting, i.e. Lax-Freidrichs for the nonlinear advective term and Crank-Nicholson for the diffusion term.
EDIT: Your solution would be more stable with a scheme such as MacCormack than doing pure implicit integration. |
September 25, 2017, 13:13 |
#8 | |
Marco Ghiani
Rep Power: 15 |
September 25, 2017, 13:14 |
#9 | |
Marco Ghiani
Rep Power: 15 |
September 25, 2017, 13:27 |
#10 |
Rep Power: 73 |
September 25, 2017, 19:35 |
Operator splitting
#11 |
Selig
Rep Power: 11 |
Given you are working with the viscous Burgers equation your scheme will look like this: First we solve for the advection term: where Secondly, we solve for the viscous term: You will get a tridiagonal matrix [1, -2, 1] If the operators do not commute you will have to perform either Strang splitting or alternate the splitting to get second order accuracy. |
September 26, 2017, 04:04 |
#12 |
Rep Power: 73 |
Actually, you do not need to perform a splitting, just discretize the convective and diffusive and solve |
September 26, 2017, 11:43 |
#13 |
Selig
Rep Power: 11 |
I agree with you. Is there a reason why people would rather not use operator splitting aside from the problem of non-commuting operators?
September 26, 2017, 11:50 |
#14 | |
Rep Power: 73 |
The problem is in the order of accuracy of the adopted splitting where some operators do not commute. |
Guide: Writing Equations in LaTeX on the CFD Online Forums | pete | Site Help, Feedback & Discussions | 27 | May 19, 2022 04:19 |
Implicit versus Explicit | Deepak | Main CFD Forum | 17 | November 7, 2015 14:14 |
Calculation of the Governing Equations | Mihail | CFX | 7 | September 7, 2014 07:27 |
CFD governing equations | m.gos | Main CFD Forum | 0 | April 30, 2011 15:21 |
Implicit Euler equations | moein_joon27 | Main CFD Forum | 1 | January 13, 2011 15:43 |
