October 13, 2017, 14:40 |
#41 | |
Filippo Maria Denaro
Rep Power: 73 |
Not sure about you index notation in the PPE but you should have a row of the pressure matrix modified congruently by the BC while, conversely, I see still 5 elements in the row instead of 4. Then, while computing cont(i,j) have you already stored the physical values of the velocity in ufnew and vfnew at the boundaries? |
October 13, 2017, 15:02 |
Ppe
#42 |
Selig
Rep Power: 11 |
Dr. Denaro,
The way I am handling the boundary conditions for the PPE is as outlined in the image (I did not have room in the message box.) The only thing I am doing differently, is |
October 13, 2017, 15:08 |
#43 |
Rep Power: 73 |
Ok, that's correct, I was wrong in reading the equation
October 13, 2017, 16:29 |
#44 | |
Selig
Rep Power: 11 |
So with my current formulation, is my BC for my PPE correct? I.e., even for outflow BC is setting . It illudes me why my PPE won't converge due to a simple outflow BC... |
October 13, 2017, 17:40 |
#45 |
Rep Power: 73 |
Correct for Dirichlet bc.s on the velocity but how do you work for Neuman on the velocity??
October 14, 2017, 14:30 |
Outflow BC for PPE
#46 |
Selig
Rep Power: 11 |
The way I am handling the outflow BC is as follows
Using as defined in the previous post, I am imposing on the continuity equation that is formed from the veleocities which gives Since I am interested in imposing the Neumann BC at the outlet (i=nx) I get I am imposing that which gives Expanding the terms and using SOR at the boundary I get Now, it is only after I calculate the un, vn (the corrector step), do I set Something else to mention, if I set P(2,2) = 1.0 and using un(nx,j) = un(nx-1,j), vn(nx,j) = vn(nx-1,j), while my solver doesnt crash (because I've created a fixed point), my jet doesnt ever really form. By that I mean the jet stops growing after 200 time steps. My theory is that since my pressure BCs are not correct, its affecting the jet formation. To further isolate any bug, I have rewritten my solver in Matlab where I am using a basic explicit euler time integration. Code:
close all; clear all; Lx = 1; Ly = 1; nx = 30; ny = 30; dx = Lx/(nx-1); dy = Ly/(ny-1); dt = 0.0001; rho = 1.0; nu = 0.1; omega = 1.9; IterMax = 15000; tol = 1e-6; tEnd = 2.00; x = zeros(nx,ny); y = zeros(nx,ny); R = zeros(nx,ny); P = zeros(nx,ny); Res = zeros(nx,ny); Cx = zeros(nx,ny); Cy = zeros(nx,ny); Dx = zeros(nx,ny); Dy = zeros(nx,ny); u = zeros(nx,ny); v = zeros(nx,ny); us = zeros(nx,ny); vs = zeros(nx,ny); un = zeros(nx,ny); vn = zeros(nx,ny); uf = zeros(nx,ny); vf = zeros(nx,ny); ufs = zeros(nx,ny); vfs = zeros(nx,ny); Qx = zeros(nx,ny); Qy = zeros(nx,ny); DivU = zeros(nx,ny); for j=1:ny for i=1:nx u(i,j) = 0.0; v(i,j) = 0.0; P(i,j) = 0.0; end end for j=1:ny for i=1:nx x(i,j) = (i-1)*dx; y(i,j) = (j-1)*dy; end end t = 0.0; while (t < tEnd) for j=1:ny for i=1:nx-1 uf(i,j) = 0.5*(u(i+1,j) + u(i,j)); end end for j=1:ny-1 for i=1:nx vf(i,j) = 0.5*(v(i,j+1) + v(i,j)); end end for j=2:ny-1 for i=2:nx-1 Dx(i,j) = nu*(1.0/dx^2*(u(i+1,j) - 2.0*u(i,j) + u(i-1,j)) + 1.0/dy^2*(u(i,j+1) - 2*u(i,j) + u(i,j-1))); Dy(i,j) = nu*(1.0/dx^2*(v(i+1,j) - 2.0*v(i,j) + v(i-1,j)) + 1.0/dy^2*(v(i,j+1) - 2*v(i,j) + v(i,j-1))); Cx(i,j) = (1.0/dx)*(uf(i,j).*uf(i,j) - uf(i-1,j).*uf(i-1,j)) + (1.0/dy)*(uf(i,j).*vf(i,j) - uf(i,j-1).*vf(i,j-1)); Cy(i,j) = (1.0/dx)*(uf(i,j).*vf(i,j) - uf(i-1,j).*vf(i-1,j)) + (1.0/dy)*(vf(i,j).*vf(i,j) - vf(i,j-1).*vf(i,j-1)); Qx(i,j) = -Cx(i,j) + Dx(i,j); Qy(i,j) = -Cy(i,j) + Dy(i,j); us(i,j) = u(i,j) + dt*Qx(i,j); vs(i,j) = v(i,j) + dt*Qy(i,j); end end us(1,:) = un(1,:); us(nx,:) = un(nx,:); us(:,1) = un(:,1); us(:,ny) = un(:,ny); vs(1,:) = vn(1,:); vs(nx,:) = vn(1,:); vs(:,1) = vn(:,1); vs(:,ny) = vn(:,ny); for j=1:ny for i=1:nx-1 ufs(i,j) = 0.5*(us(i+1,j) + us(i,j)); end end for j=1:ny-1 for i=1:nx vfs(i,j) = 0.5*(vs(i,j+1) + vs(i,j)); end end for j=3:ny-2 for i=3:nx-2 R(i,j) = (rho/dt)*((1/dx)*(ufs(i,j) - ufs(i-1,j)) + (1/dy)*(vfs(i,j) - vfs(i,j-1))); end end Iter = 0; while (Iter <= IterMax) for j=3:ny-2 for i=3:nx-2 P(i,j) = (1-omega)*P(i,j) + omega/(2/dx^2 + 2/dy^2)*((P(i+1,j) + P(i-1,j))/dx^2 + (P(i,j+1) + P(i,j-1))/dy^2 - R(i,j)); end end for j=3:ny-2 R(2,j) = (rho/dt)*((1/dx)*(ufs(2,j) - un(1,j)) + (1/dy)*(vfs(2,j) - vfs(2,j-1))); P(2,j) = (1-omega)*P(2,j) + omega/(1/dx^2 + 2/dy^2)*((1/dx^2)*P(3,j) + (1/dy^2)*(P(2,j+1) + P(2,j-1)) - R(2,j)); %Outflow BC, point of interest R(nx-1,j) = (rho/dt)*((1.0/dx)*(un(nx-1,j) - ufs(nx-2,j)) + (1/dy)*(vfs(nx-1,j) - vfs(nx-1,j-1))); P(nx-1,j) = (1-omega)*P(nx-1,j) + omega/(1/dx^2 + 2/dy^2)*((1/dx^2)*P(nx-2,j) + (1/dy^2)*(P(nx-1,j+1) + P(nx-1,j-1)) - R(nx-1,j)); end for i=3:nx-2 R(i,2) = (rho/dt)*((1/dx)*(ufs(i,2) - ufs(i-1,2)) + (1/dy)*(vfs(i,2) - vn(i,1))); P(i,2) = (1-omega)*P(i,2) + omega/(2/dx^2 + 1/dy^2)*((1/dx^2)*(P(i+1,2) + P(i-1,2)) + (1/dy^2)*P(i,3) - R(i,2)); R(i,ny-1) = (rho/dt)*((1/dx)*(ufs(i,ny-1) - ufs(i-1,ny-1)) + (1/dy)*(vn(i,ny) - vfs(i,ny-2))); P(i,ny-1) = (1-omega)*P(i,ny-1) + omega/(2/dx^2 + 1/dy^2)*((1/dx^2)*(P(i+1,ny-1) + P(i-1,ny-1)) + (1/dy^2)*P(i,ny-2) - R(i,ny-1)); end R(2,ny-1) = (rho/dt)*((1/dx)*(ufs(2,ny-1) - un(1,ny-1)) + (1/dy)*(v(2,ny) - vfs(2,ny-1))); P(2,ny-1) = (1-omega)*P(2,ny-1) + omega/(1/dx^2 + 1/dy^2)*((1/dx^2)*P(3,ny-1) + (1/dy^2)*P(2,ny-2) - R(2,ny-1)); R(nx-1,2) = (rho/dt)*((1/dx)*(un(nx,2) - ufs(nx-2,2)) + (1/dy)*(vfs(nx-1,2) - vn(nx-1,1))); P(nx-1,2) = (1-omega)*P(nx-1,2) + omega/(1/dx^2 + 1/dy^2)*((1/dx^2)*P(nx-2,2) + (1/dy^2)*P(nx-1,3) - R(nx-1,2)); R(nx-1,ny-1) = (rho/dt)*((1/dx)*(un(nx,ny-1) - ufs(nx-2,ny-1)) + (1/dy)*(vn(nx-1,ny) - vfs(nx-1,ny-2))); P(nx-1,ny-1) = (1-omega)*P(nx-1,ny-1) + omega/(1/dx^2 + 1/dy^2)*((1/dx^2)*P(nx-2,ny-1) + (1/dy^2)*P(nx-1,ny-2) - R(nx-1,ny-1)); %R(2,2) = (rho/dt)*((1.0/dx)*(ufs(2,2) - un(1,2)) + (1.0/dy)*(vfs(2,2) - vn(2,1))); %P(2,2) = (1-omega)*P(2,2) + omega/(1.0/dx^2 + 1.0/dy^2)*((1.0/dx^2)*P(3,2) + (1.0/dy^2)*P(2,3) - R(2,2)); P(2,2) = 1.0; Res = 0.0; for j=3:ny-2 for i=3:nx-2 Res(i,j) = ((1.0/dx^2)*(P(i-1,j) - 2*P(i,j) + P(i+1,j)) + (1.0/dy^2)*(P(i,j-1) - 2*P(i,j) + P(i,j+1))) - R(i,j); end end error = sqrt(dx*dy*sum(sum(Res.^2))); if (error >= tol) Iter = Iter + 1; else fprintf("PPE has Converged") break; end end P(1,:) = P(2,:) + (dx/dt)*(us(1,:) - un(1,:)); P(nx,:) = P(nx-1,:) - (dx/dt)*(us(nx,:) - un(nx,:)); P(:,1) = P(:,2) + (dy/dt)*(vs(:,1) - vn(:,1)); P(:,ny) = P(:,ny-1) - (dy/dt)*(vs(:,ny) - vn(:,ny)); for j=2:ny-1 for i=2:nx-1 un(i,j) = us(i,j) - (dt/(2.0*dx*rho))*(P(i+1,j) - P(i-1,j)); vn(i,j) = vs(i,j) - (dt/(2.0*dy*rho))*(P(i,j+1) - P(i,j-1)); end end un(:,ny) = 0.0; %basic inlet profile un(1,12:15) = 1.0; %outflow BC for u un(nx,:) = u(nx-1,j); un(:,1) = 0.0; %Set outflow BC for v vn(nx,:) = v(nx-1,j); vn(1,:) = 0.0; vn(:,ny) = 0.0; vn(:,1) = 0.0; u = un; v = vn; t = t + dt contourf(x,y,un,20); colormap jet xlabel('x'); ylabel('y'); title(['t = ',num2str(t)]); pause(0.001); end |
October 14, 2017, 14:43 |
#47 |
Rep Power: 73 |
"I am imposing that which gives"
This way I don't see any Neumann BC.s ... you should start from the relation u*=u^n+1+ dP/dx - > du*/dx=d^n+1/dx+d2P/dx2 -> du*/dx=d2P/dx2 |
October 15, 2017, 12:59 |
outflow BC for PPE
#48 |
Selig
Rep Power: 11 |
Given the relation you provided, I have tried to formulate a BC, and this is what I have.
I consider Using the relation and evaluating at the outflow I get Using SOR and evaluating at the boundary I get I then evaluate at i=nx-1. Is there literature on outflow BC for PPEs on colocated grids? I was unable to find anything... |
October 15, 2017, 13:47 |
#49 |
Rep Power: 73 |
Well, we need to be careful in the index and colocation. I assume (I hope to be right) that i=nx is the index for the faces outflow. The equation for the pressure is written in the interior node shifted from the outflow face by -dx/2, right?
Therefore, the Neumann BC.s is fromally written on the faces outflow then you insert them in the PPE. However, I see that one can work in different ways. I believe that a simple way is to write the BC directly at the node of the PPE, this way you have a tridiagonal system along y |
October 15, 2017, 14:10 |
Neumann BC for PPE
#50 | |
Selig
Rep Power: 11 |
October 15, 2017, 14:17 |
#51 | |
Rep Power: 73 |
Maybe the pressure equation written at i=nx-1, isnt'it? To tell the truth, at present I don't remember a textbook where you can find an example for the implementation of outflow BC.s in the pressure equation on colocated grid. |
October 15, 2017, 14:36 |
BC
#52 | |
Selig
Rep Power: 11 |
No problem. My mistake, it should be i=nx-1.
Now since I am evaluating the PPE at the boundary I then insert Solving for I get And this goes into the PPE evaluated at i=nx-1? I feel like this is not right. Pardon the foolishness. |
October 15, 2017, 15:03 |
#53 | |
Rep Power: 73 |
First, be careful to the ratio rho/dt you missed. Then, you can totally disregard the term in x and solving only the Pyy=(rho/dt) d(v*)/dy at i=nx-1. This way, you do not need to discretize the Neumann BC. |
October 15, 2017, 17:24 |
Boundary condition
#54 |
Selig
Rep Power: 11 |
October 15, 2017, 17:32 |
#55 |
Rep Power: 73 |
Seems ok. Do not forget that you have in the corners to add the BC.s also for v^n+1. Generally the cycles of the SOR are programmed differently, out of the do cycles.
Problem with divergence | TDK | FLUENT | 13 | December 14, 2018 07:00 |
LES of Turbulent Jet | knuckles | OpenFOAM Running, Solving & CFD | 1 | March 31, 2016 20:33 |
turbulent jet | ramo | Main CFD Forum | 1 | September 4, 2005 08:43 |
Modelling a turbulent jet and k-epsilon constants | Ant | Siemens | 3 | January 24, 2005 16:56 |
Turbulent Intensity good or bad for a jet | Christian | Main CFD Forum | 0 | November 19, 2003 06:47 |
