October 5, 2017, 15:40 |
#21 |
Filippo Maria Denaro
Rep Power: 73 |
That is the profile at the inlet?? First, the magnitude order is 10^-8, then it has positive and negative values...something is wrong
October 5, 2017, 16:14 |
Jet profile
#22 |
Selig
Rep Power: 11 |
I agree with you. I get larger values if I have my pressure initial condition to be 1.0. I am thinking there is a bug in my solver and its not my inlet.
October 9, 2017, 17:22 |
Stepping back
#23 |
Selig
Rep Power: 11 |
To better isolate the problem, I have gone back to my 2D incompressible code. To ensure my code is validated I tested it on the lid driven cavity and I get good results. I now am trying to setup a 2D planar jet.
What I have found is that when I setup the outflow boundary conditions, my solver crashes, i.e. I get NaNs. It is interesting to note that I only crash when I have outflow BC (Neumann BC). If I set one of the corner pressure BCs to 1.0 then my solver does not crash, however my numerical solution runs into problems as the compatibility condition isnt fully satisfied. I have attached a link to my source code. A second pair of eyes would be greatly appreciated as I am unsure what I am doing wrong. Technical specs of the solver: - Shu TVD RK3 for both advection and diffusion - Collocated-grid solver with Rhie-Chow interpolation - Cartesian grid - boundary conditions for the intermediate velocity (predictor step) are from Kim and Moin - No slip BC on all asides except the inlet and outlet |
October 10, 2017, 04:48 |
#24 |
Rep Power: 73 |
I would work on these cases:
1) laminar Poiseuille solution: inlet parabolic profile, outlet Neumann. 2) analytical Taylor solution: periodic conditions |
October 10, 2017, 10:51 |
Jet Solver
#25 |
Selig
Rep Power: 11 |
Dr. Denaro,
With regards to the first benchmark, my solver crashes unless I remove the null space of PPE solution, i.e. P(2,2) = 1.0. Given I am working with the BCs of Kim and Moin, is there any particular treatment for the outlet BC I am not taking into account? With respect to the TG vortex benchmark, I have not tested my solver on that yet. |
October 10, 2017, 11:29 |
#26 |
Rep Power: 73 |
If it crashes then there is an error in the bc.s that do not fulfill the compatibility condition...
October 10, 2017, 12:25 |
Jet
#27 |
Selig
Rep Power: 11 |
I am of the same opinion, however I am unsure how my boundary conditions in the corrector step would not be satisfying the compatibility condition. I am of the understanding that a first order approximation for the outflow conditions is not optimal, but it should still not cause numerical problems as such.
! Main time integration loop call CartesianGrid(x,y,dx,dy) call InitialCondition(u,v,P) t = 0.0 do while (t <= t_end) call Momentum(u, v, uMtm, vMtm) do j=2,ny-1 do i=2,nx-1 us1(i,j) = u(i,j) + dt*uMtm(i,j) vs1(i,j) = v(i,j) + dt*vMtm(i,j) end do end do call IntermediateBC(us1,vs1,un,vn,P) call Momentum(us1,vs1,uMtm1,vMtm1) do j=2,ny-1 do i=2,nx-1 us2(i,j) = (3.0/4.0)*u(i,j) + (1.0/4.0)*us1(i,j) + (dt/4.0)*uMtm1(i,j) vs2(i,j) = (3.0/4.0)*v(i,j) + (1.0/4.0)*vs1(i,j) + (dt/4.0)*vMtm1(i,j) end do end do call IntermediateBC(us2,vs2,un,vn,P) call Momentum(us2,vs2,uMtm2,vMtm2) do j=2,ny-1 do i=2,nx-1 us(i,j) = (1.0/3.0)*u(i,j) + (2.0/3.0)*us2(i,j) + ((2.0*dt)/3.0)*uMtm2(i,j) vs(i,j) = (1.0/3.0)*v(i,j) + (2.0/3.0)*vs2(i,j) + ((2.0*dt)/3.0)*vMtm2(i,j) end do end do call IntermediateBC(us,vs,un,vn,P) call PressureSolver(P,us,vs,un,vn) do j=2,ny-1 do i=2,nx-1 un(i,j) = us(i,j) - (dt/(2.0*dx*rho))*(P(i+1,j) - P(i-1,j)) vn(i,j) = vs(i,j) - (dt/(2.0*dy*rho))*(P(i,j+1) - P(i,j-1)) end do end do ! Set BCs for u^(n+1), v^(n+1) do i=1,nx un(i,1) = 0.0 un(i,ny) = 0.0 vn(i,1) = 0.0 vn(i,ny) = 0.0 end do do j=15,17 un(1,j) = y(1,j)*(2.0 - y(1,j)) end do do j=1,ny un(nx,j) = un(nx-1,j) vn(1,j) = 0.0 vn(nx,j) = vn(nx-1,j) end do u = un v = vn t = t + dt print *, "t = ", t end do ! BCs subroutine IntermediateBC (us, vs, un, vn, P) implicit none integer :: i, j double precision, dimension(nx,ny), intent(inout) :: un, vn, us, vs, P do j=1,ny us(1,j) = un(1,j) + (dt/dx)*(P(2,j) - P(1,j)) us(nx,j) = un(nx,j) + (dt/dx)*(P(nx,j) - P(nx-1,j)) vs(1,j) = vn(1,j) + (dt/dx)*(P(2,j) - P(1,j)) vs(nx,j) = vn(nx,j) + (dt/dx)*(P(nx,j) - P(nx-1,j)) end do do i=1,nx us(i,1) = un(i,1) + (dt/dy)*(P(i,2) - P(i,1)) us(i,ny) = un(i,ny) + (dt/dy)*(P(i,ny) - P(i,ny-1)) vs(i,1) = vn(i,1) + (dt/dy)*(P(i,2) - P(i,1)) vs(i,ny) = vn(i,ny) + (dt/dy)*(P(i,ny) - P(i,ny-1)) end do return end subroutine IntermediateBC !Momentum discretization for u, v subroutine Momentum (u, v, uMtm, vMtm) implicit none integer :: i, j double precision, dimension(nx,ny), intent(out) :: uMtm, vMtm double precision, dimension(nx,ny), intent(inout) :: u, v double precision, dimension(nx,ny) :: Cx, Cy; double precision, dimension(nx,ny) :: Vx, Vy double precision, dimension(nx,ny) :: uf, vf call FaceVelocities(u,v,uf,vf) call BoundaryConditions(uf,vf) do j=2,ny-1 do i=2,nx-1 Cx(i,j) = (1.0/dx)*(uf(i,j)*uf(i,j) - uf(i-1,j)*uf(i-1,j)) + (1.0/dy)*(uf(i,j)*vf(i,j) - uf(i,j-1)*vf(i,j-1)) Cy(i,j) = (1.0/dx)*(uf(i,j)*vf(i,j) - uf(i-1,j)*vf(i-1,j)) + (1.0/dy)*(vf(i,j)*vf(i,j) - vf(i,j-1)*vf(i,j-1)) Vx(i,j) = nu*((1.0/dx**2)*(u(i-1,j) - 2.0*u(i,j) + u(i+1,j)) + (1.0/dy**2)*(u(i,j-1) - 2.0*u(i,j) + u(i,j+1))) Vy(i,j) = nu*((1.0/dx**2)*(v(i-1,j) - 2.0*v(i,j) + v(i+1,j)) + (1.0/dy**2)*(v(i,j-1) - 2.0*v(i,j) + v(i,j+1))) uMtm(i,j) = -Cx(i,j) + Vx(i,j) vMtm(i,j) = -Cy(i,j) + Vy(i,j) end do end do return end subroutine |
October 10, 2017, 13:48 |
#28 |
Rep Power: 73 |
I have not read the code, are you following exactly the same formulation proposed in the paper of Kim and Moin but applied on a non-steggered grid?
Can you run a case where the inflow profile is parabolic and you set the same profile at the outflow so that you set Dirichlet BC.s everywhere? I am curious to see if the code still crashes. If it works without fixing a pressure value and the Poiseuille solution is obtained, then we can approach the problem of the Neumann BC at the outflow. PS: of course, set a low Re number, for example 10. |
October 10, 2017, 16:37 |
Solver error
#29 |
Selig
Rep Power: 11 |
I am using the BC method of Kim and Moin on a collocated grid and with purely explicit time integration. Eventually I want to have implicit treatment of diffusion, but I want to work in a controlled environment to minimize error. Attached is a photo where at the outlet I assign the profile I used for the inlet.
I was curious if you had a chance to look at my code if you saw anything wrong. I've gone over the entire code (only 300 lines) and still don't see an error. EDIT: Here is a plot of my inlet profile EDIT 2: In terms of the type of projection method, I am using the pressure-free projection method like that of Kim and Moin.. |
October 10, 2017, 16:55 |
#30 |
Rep Power: 73 |
1) if you use a fully explicit method, the BC.s described in the paper by Kim and Moin for the intermediate velocity are not used at all in your code! You just need to set v^n+1 or dp/dn on the boundary
2) what about the plot? is still the inlet of the jet case? |
October 10, 2017, 17:23 |
Intermediate BC
#31 |
Selig
Rep Power: 11 |
Dr. Denaro, thank you for pointing out my blunder!. Since I removed my implicit solver, I forgot that the intermediate BC has to be changed. I have now set u* and v* to be u^n+1 and v^n+1 on the boundary. I changed my outlet to be a standard outlet, un(nx,j) = un(nx-1,j), vn(nx,j) = vn(nx-1,j), and I still crash...
subroutine IntermediateBC (us, vs, un, vn, P) implicit none integer :: i, j double precision, dimension(nx,ny), intent(out) :: un, vn, us, vs, P do j=1,ny us(1,j) = un(1,j) us(nx,j) = un(nx,j) vs(1,j) = vn(1,j) vs(nx,j) = vn(nx,j) end do do i=1,nx us(i,1) = un(i,1) us(i,ny) = un(i,ny) vs(i,1) = vn(i,1) vs(i,ny) = vn(i,ny) end do return end subroutine IntermediateBC |
October 10, 2017, 17:30 |
#32 | |
Rep Power: 73 |
That should not affect the Poisson solver... I strongly suggest to start debugging the code in a careful way: 1) setup the BC for the exact Poiseuille solution with Dirichlet inflow and outflow. 2) Start only the first time step and compute the intermediate velocity and the pressure field. Check if the Poisson solver converges. 3) Sum them and check the final divergence of the velocity |
October 12, 2017, 14:05 |
Solver error
#33 |
Selig
Rep Power: 11 |
Something I did not consider is, do I need to be setting boundary conditions for Vx ,Vy,Cx,Cy? (Vx is Viscous terms for u-mom and Cx is convection terms for u-mom?)
Example: Code:
Cx(i,j) = (1.0/dx)*(uf(i,j)*uf(i,j) - uf(i-1,j)*uf(i-1,j)) + (1.0/dy)*(uf(i,j)*vf(i,j) - uf(i,j-1)*vf(i,j-1)) Cy(i,j) = (1.0/dx)*(uf(i,j)*vf(i,j) - uf(i-1,j)*vf(i-1,j)) + (1.0/dy)*(vf(i,j)*vf(i,j) - vf(i,j-1)*vf(i,j-1)) Vx(i,j) = nu*((1.0/dx**2.0)*(u(i-1,j) - 2.0*u(i,j) + u(i+1,j)) + (1.0/dy**2.0)*(u(i,j-1) - 2.0*u(i,j) + u(i,j+1))) Vy(i,j) = nu*((1.0/dx**2.0)*(v(i-1,j) - 2.0*v(i,j) + v(i+1,j)) + (1.0/dy**2.0)*(v(i,j-1) - 2.0*v(i,j) + v(i,j+1))) uMtm(i,j) = -Cx(i,j) + Vx(i,j) vMtm(i,j) = -Cy(i,j) + Vy(i,j) EDIT: I tried using standard explicit euler and I still get the same result. I was thinking my RK time stepping could have been creating an error.. |
October 12, 2017, 14:25 |
#34 |
Rep Power: 73 |
viscous and convective terms BC.s are a consequence of the BC.s prescribed for the velocity
October 12, 2017, 15:22 |
#35 |
Selig
Rep Power: 11 |
Thats what I thought, just wanted to double check on a numerical level. So the divergence of the velocity field is quite small, however when I sum it, it gets rather large...2.2 at t = 1.0. The L2 error of the PPE is 9.6818155843085360E-007.
I am determining continuity via Code:
ufnew(i,j) = 0.5*(us(i+1,j) + us(i,j)) - (dt/rho)*(P(i+1,j) - P(i,j)) vfnew(i,j) = 0.5*(vs(i,j+1) + vs(i,j)) - (dt/rho)*(P(i,j+1) - P(i,j)) cont(i,j) = (1.0/dx)*(ufnew(i,j) - ufnew(i-1,j)) + (1.0/dy)*(vfnew(i,j) - vfnew(i,j-1)) Code:
subroutine PressureSolver (P, us, vs, un, vn) implicit none integer :: i, j double precision, dimension(nx,ny), intent(out) :: P double precision, dimension(nx,ny), intent(in) :: us, vs double precision, dimension(nx,ny), intent(in) :: un, vn double precision, dimension(nx,ny) :: vfs, ufs double precision, dimension(nx,ny) :: R, Res double precision, parameter :: inv_dxx = 1.0/dx**2.0 double precision, parameter :: inv_dyy = 1.0/dy**2.0 double precision, parameter :: inv_dx = 1.0/dx double precision, parameter :: inv_dy = 1.0/dy double precision, parameter :: tol = 1e-6 double precision, parameter :: iter_max = 16000 double precision, parameter :: omega = 1.96 double precision :: L2_Error integer :: it call FaceVelocities(us,vs,ufs,vfs) do j=3,ny-2 do i=3,nx-2 R(i,j) = (rho/dt)*(inv_dx*(ufs(i,j) - ufs(i-1,j)) + inv_dy*(vfs(i,j) - vfs(i,j-1))) end do end do it = 0 do while (it <= iter_max) do j=3,ny-2 do i=3,nx-2 P(i,j) = (1.0-omega)*P(i,j) + omega/(2.0*inv_dxx + 2.0*inv_dyy)*(inv_dxx*(P(i+1,j) + P(i-1,j)) + inv_dyy*(P(i,j+1) + P(i,j-1)) - R(i,j)) end do end do do j=3,ny-2 R(2,j) = (rho/dt)*(inv_dx*(ufs(2,j)- un(1,j)) + inv_dy*(vfs(2,j) - vfs(2,j-1))) P(2,j) = (1.0-omega)*P(2,j) + omega/(inv_dxx + 2.0*inv_dyy)*(inv_dxx*P(3,j) + inv_dyy*(P(2,j+1) + P(2,j-1)) - R(2,j)) R(nx-1,j) = (rho/dt)*(inv_dx*(un(nx,j) - ufs(nx-2,j)) + inv_dy*(vfs(nx-1,j) - vfs(nx-1,j-1))) P(nx-1,j) = (1.0-omega)*P(nx-1,j) + omega/(inv_dxx + 2.0*inv_dyy)*(inv_dxx*P(nx-2,j) + inv_dyy*(P(nx-1,j+1) + P(nx-1,j-1)) - R(nx-1,j)) end do do i=3,nx-2 R(i,2) = (rho/dt)*(inv_dx*(ufs(i,2) - ufs(i-1,2)) + inv_dy*(vfs(i,2)- vn(i,1))) P(i,2) = (1.0-omega)*P(i,2) + omega/(2.0*inv_dxx + inv_dyy)*(inv_dxx*(P(i+1,2) + P(i-1,2)) + inv_dyy*P(i,3) - R(i,2)) R(i,ny-1) = (rho/dt)*(inv_dx*(ufs(i,ny-1)- ufs(i-1,ny-1)) + inv_dy*(vn(i,ny) - vfs(i,ny-2))) P(i,ny-1) = (1.0-omega)*P(i,ny-1) + omega/(2.0*inv_dxx + inv_dyy)*(inv_dxx*(P(i+1,ny-1) + P(i-1,ny-1)) + inv_dyy*P(i,ny-2) - R(i,ny-1)) end do R(2,ny-1) = (rho/dt)*(inv_dx*(ufs(2,ny-1) - un(1,ny-1)) + inv_dy*(vn(2,ny) - vfs(2,ny-2))) P(2,ny-1) = (1.0-omega)*P(2,ny-1) + omega/(inv_dxx + inv_dyy)*(inv_dxx*P(3,ny-1) + inv_dyy*P(2,ny-2) - R(2,ny-1)) R(nx-1,2) = (rho/dt)*(inv_dx*(un(nx,2) - ufs(nx-2,2)) + inv_dy*(vfs(nx-1,2) - vn(nx-1,1))) P(nx-1,2) = (1.0-omega)*P(nx-1,2) + omega/(inv_dxx + inv_dyy)*(inv_dxx*P(nx-2,2) + inv_dyy*P(nx-1,3) - R(nx-1,2)) R(nx-1,ny-1) = (rho/dt)*(inv_dx*(un(nx,ny-1) - ufs(nx-2,ny-1)) + inv_dy*(vn(nx-1,ny) - vfs(nx-1,ny-2))) P(nx-1,ny-1) = (1.0-omega)*P(nx-1,ny-1) + omega/(inv_dxx + inv_dyy)*(inv_dxx*P(nx-2,ny-1) + inv_dyy*P(nx-1,ny-2) - R(nx-1,ny-1)) R(2,2) = (rho/dt)*(inv_dx*(ufs(2,2) - un(1,2)) + inv_dy*(vfs(2,2) - vn(2,1))) P(2,2) = (1.0-omega)*P(2,2) + omega/(inv_dxx + inv_dyy)*(inv_dxx*P(3,2) + inv_dyy*P(2,3) - R(2,2)) do j=3,ny-2 do i=3,nx-2 Res(i,j) = (inv_dxx*(P(i-1,j) - 2.0*P(i,j) + P(i+1,j)) + inv_dyy*(P(i,j-1) - 2.0*P(i,j) + P(i,j+1))) - R(i,j) end do end do L2_Error = 0.0 do j=3,ny-2 do i=3,nx-2 L2_Error = L2_Error + sqrt(dx*dy*abs(Res(i,j)*Res(i,j))) end do end do if (L2_Error >= tol) then it = it + 1 else print *, "PPE has converged", it print *, "L2_Error = ", L2_Error exit end if end do do j=1,ny P(1,j) = P(2,j) + (dx/dt)*(us(1,j) - un(1,j)) P(nx,j) = P(nx-1,j) - (dx/dt)*(us(nx,j) - un(nx,j)) end do do i=1,nx P(i,1) = P(i,2) + (dy/dt)*(vs(i,1) - vn(i,1)) P(i,ny) = P(i,ny-1) - (dy/dt)*(vs(i,ny) - vn(i,ny)) end do return end subroutine PressureSolver |
October 12, 2017, 15:25 |
#36 |
Rep Power: 73 |
I need to know how you collocated the velocity components ufnew,vfnew and us,vs and P
October 12, 2017, 15:50 |
Velocity collocattion
#37 |
Selig
Rep Power: 11 |
So I am collocated ufnew, vfnew as such
do j=2,ny-1 do i=2,nx-1 ufnew(i,j) = 0.5*(us(i+1,j) + us(i,j)) - (dt/rho)*(P(i+1,j) - P(i,j)) vfnew(i,j) = 0.5*(vs(i,j+1) + vs(i,j)) - (dt/rho)*(P(i,j+1) - P(i,j)) cont(i,j) = (1.0/dx)*(ufnew(i,j) - ufnew(i-1,j)) + (1.0/dy)*(vfnew(i,j) - vfnew(i,j-1)) end do end do This is also used to construct the PPE (Rhie-Chow method). |
October 12, 2017, 16:58 |
#38 |
Rep Power: 73 |
According to your notation, us, vs, P are co-located while uf(i,j) is staggered at i+1/2 and vf(i,j) at j+1/2.
Considering only the x-component, you have (1.0/dx)*(ufnew(i,j) - ufnew(i-1,j))= (1.0/dx)*(0.5*(us(i+1,j) + us(i,j)) - (dt/rho)*(P(i+1,j) - P(i,j)) - 0.5*(us(i,j) + us(i-1,j)) + (dt/rho)*(P(i,j) - P(i-1,j))) That leads to the standard Poisson equation. But at the boundary you have to impose the correct velocity, for example at the inflow you substitute the physical velocity ufnew(i-1,j)=uinflow so that (1.0/dx)*(ufnew(i,j) - ufnew(i-1,j))= (1.0/dx)*(0.5*(us(i+1,j) + us(i,j)) - (dt/rho)*(P(i+1,j) - P(i,j)) - uinflow) |
October 13, 2017, 00:53 |
#39 |
Sagar
Rep Power: 9 |
Hi Selig,
I am working on DNS of free circular round jet for Re=1000 to 2000. At the inlet you can go for velocity profile suggested by Michalke et al. (Tan hyperbolic profile). which is good approximation of velocity profile in near field region of the jet. |
October 13, 2017, 14:26 |
PPE boundary conditions
#40 |
Selig
Rep Power: 11 |
Problem with divergence | TDK | FLUENT | 13 | December 14, 2018 07:00 |
LES of Turbulent Jet | knuckles | OpenFOAM Running, Solving & CFD | 1 | March 31, 2016 20:33 |
turbulent jet | ramo | Main CFD Forum | 1 | September 4, 2005 08:43 |
Modelling a turbulent jet and k-epsilon constants | Ant | Siemens | 3 | January 24, 2005 16:56 |
Turbulent Intensity good or bad for a jet | Christian | Main CFD Forum | 0 | November 19, 2003 06:47 |
