Integration of Partial Differential Equations |
September 11, 2017, 13:18 |
Matt Ridzon
Rep Power: 12 |
Hello! I know this forum is dedicated to CFD and my question below isn't exactly related to such. But I know this forum is full of fluid analysts, so I thought perhaps someone on here might be able to help me out. And so hopefully the moderators won't delete my post.
In the attached JPG, I boxed in an area where I'm working through the integration of the 2D cylindrical axisymmetric Navier-Stokes equations. z = axis along the centerline of the pipe p = pressure, which is a function of z r = radius of a pipe (varies from centerline to R) vz = velocity, which is a function of r mu = constant value (i.e., viscosity) R = constant value (i.e., outer radius) Near the top of the boxed area of the attachment, I show the start of the integration. I have to integrate twice with respect to r, to get the answer listed at the bottom of the page. I can't seem to get the right answer and I believe the last term might be causing my trouble (i.e., the term noted as needing integration by parts). Basically, I need to know how to solve this partial differential equation to its analytical solution, but I'm not sure what I'm doing wrong. Thanks in advance, M Ridzon |
September 11, 2017, 13:34 |
Filippo Maria Denaro
Rep Power: 73 |
If you are studying the Hagen-Poiseuille solution, have a look to the book of White, Sec.4.10
September 11, 2017, 13:53 |
#3 | |
Matt Ridzon
Rep Power: 12 |
Thanks, M Ridzon |
September 11, 2017, 13:55 |
Rep Power: 73 |
September 11, 2017, 14:26 |
#5 | |
Matt Ridzon
Rep Power: 12 |
Thanks again! M Ridzon |
grid generation with elliptic partial differential equations. | gorkemocalan | Main CFD Forum | 0 | October 1, 2015 14:39 |
Low Reynolds K Epsilon Launder Sharma Model Functions Doubt... | Ruonin | Main CFD Forum | 17 | February 17, 2014 09:52 |
modelling Differential equations in a udf | RikardMNorén | Fluent UDF and Scheme Programming | 2 | October 1, 2013 03:36 |
numerical integration of a set of ordinary partial differential equation | wlt_1985 | FLUENT | 0 | November 5, 2010 16:17 |
MultiDimensional Partial Differential Equations. | Aditya | Main CFD Forum | 2 | October 28, 2005 05:03 |
