Getting incorrect u-velocity profile by solution
Old   September 9, 2017, 10:49
Default Getting incorrect u-velocity profile by solution
Dharma
Dharma Vedula is on a distinguished road
Obtaining wrong u-velocity profiles. Velocity at all y increases in x-direction. Results below for laminar flow through rectangular microchannel (H=0.1 mm, W=0.2 mm, L=50 mm, Re=100, Inlet velocity=0.449 m/s). Wrote SIMPLER algorithm in Python code. Followed Versteeg and Malalasekra. Is is due to any error in p or u boundary condition?
0.00000.00000.00000.00000.00000.00000.00000.00000.00000.00000.00000.00000.00000.0000
0.01670.44900.40040.41420.42670.43830.44900.45890.46820.47690.48540.49370.50200.5031
0.03330.44900.63190.65510.67510.69360.71080.72660.74130.75530.76880.78200.79560.7974
0.05000.44900.71100.73760.76000.78060.79970.81730.83380.84940.86450.87930.89400.8960
0.06670.44900.63540.65860.67850.69690.71380.72950.74410.75800.77150.78460.79750.7993
0.08330.44900.40170.41560.42810.43970.45030.46010.46930.47800.48650.49480.50280.5039
0.10000.00000.00000.00000.00000.00000.00000.00000.00000.00000.00000.00000.00000.0000
Dharma Vedula is offline   Reply With Quote
Old   September 9, 2017, 19:42
Lane Carasik
lcarasik is on a distinguished road
Without more information, it looks like you are applying your velocity profile boundary condition on your bottom wall (see the 0.1 in the line of 0.0).
lcarasik is offline   Reply With Quote
Old   September 9, 2017, 21:57
Dharma
I am sorry. I forgot to remove the first column. It represents the distance in y-direction (vertical direction) from y=0 to y=0.1 (height of the rectangular channel). The second column onwards - the velocities at different distances from inlet in x-direction (flow direction).
But the pressure computed from this code is matching with standard value for laminar tube flow.
Pressure drop obtained from the present analysis = 21.85 kPa
Pressure drop calculated from Fanning's equation = 23.90 kPa
I wrote code for steady state SIMPLER algorithm.
I am giving below the profile after removing the first column. Sorry for the inconvenience, and thank you very much.
0.0000 0.0000 0.0000 0.0000 0.0000 0.0000 0.0000 0.0000 0.0000 0.0000 0.0000 0.0000 0.0000
0.4490 0.4004 0.4142 0.4267 0.4383 0.4490 0.4589 0.4682 0.4769 0.4854 0.4937 0.5020 0.5031
0.4490 0.6319 0.6551 0.6751 0.6936 0.7108 0.7266 0.7413 0.7553 0.7688 0.7820 0.7956 0.7974
0.4490 0.7110 0.7376 0.7600 0.7806 0.7997 0.8173 0.8338 0.8494 0.8645 0.8793 0.8940 0.8960
0.4490 0.6354 0.6586 0.6785 0.6969 0.7138 0.7295 0.7441 0.7580 0.7715 0.7846 0.7975 0.7993
0.4490 0.4017 0.4156 0.4281 0.4397 0.4503 0.4601 0.4693 0.4780 0.4865 0.4948 0.5028 0.5039
Old   September 12, 2017, 03:35
Lane Carasik
It looks as if there is an issue with your coefficients of your solver. Did you test it with a lid-driven cavity case? Elsewise, your solution should be symmetric along the centerline.
boundary condition p, boundary condition u, simpler algorithm, simpler code
atmBoundaryLayerInletVelocity - Velocity Profile not continuous through domain sdfij6354 OpenFOAM Running, Solving & CFD 3 July 26, 2017 17:16
UDF error - parabolic velocity profile - 3D turbine Zaqie Fluent UDF and Scheme Programming 9 June 25, 2016 20:08
How to apply an outlet velocity profile to another inlet? siw FLUENT 4 April 10, 2013 12:19
unable to get parabolic velocity profile with pimplefoam houkensjtu OpenFOAM 4 October 8, 2012 05:41
Variables Definition in CFX Solver 5.6 R P CFX 2 October 26, 2004 03:13
