Convergence with SIMPLE algorithm simulating water flow in a valve |
August 24, 2017, 10:34 |
power
Rep Power: 12 |
I'm simulating a simple water flow through a control valve. So the flow is incompressible and steady. Max reached internal velocity is less than 100m/s. I'm using ACE+ as software, of ESI Group (the same now owns OpenFOAM) which uses the SIMPLE algorithm. As boundary conditions, I set pressure, normal velocity, turbulence intensity, and the inlet diameter for the dissipation rate calculation in inlet; while in the outlet I set the fixed pressure, kinetic energy and again the outlet (=inlet) diameter for the dissipation rate calculation :
It seems very converging in the beginning but then it does not converge. I attached a picture imageACE+.jpg of the normalized residual plot and the mass imbalance. If I let the solver continue to simulate then the residuals will oscillate but never converge, and sometimes they are very oscillating after 2000 iterations, and globally all normalized residuals never go down 0.1 value. What do you suggest to do to get convergence? Is it a good setting? What do you suggest in general to do this type of simulations? Even if you don't know the software, how would you set this type of problems? Thanks in advance for any useful advice! Last edited by enginpower; August 24, 2017 at 10:39. Reason: grammar errors |
August 24, 2017, 12:24 |
Filippo Maria Denaro
Rep Power: 73 |
Have you tried also different RANS turbulence model? What about the grid resolution? The geometry of the valve is axisymmetric?
August 25, 2017, 07:24 |
power
Rep Power: 12 |
I tried k-epsilon model and SST k-omega model: always the same behaviour
The grid is very dense, let's say about 7M cells, obviously more dense where flow goes through holes of the internal parts of the valve, and less dense in the large duct of the bell close to the inlet and outlet section. I created the grid with the Esi software for mesh generation, that is VisCart. About generated mesh, it passes all validation checks Yes, the valve is symmetric, so I'm simulating just a half Last edited by enginpower; August 25, 2017 at 12:40. |
Issues on the simulation of high-speed compressible flow within turbomachinery | dowlee | OpenFOAM Running, Solving & CFD | 11 | August 6, 2021 07:40 |
Mass imbalance problem in multiphase water and steam CFX case | Antech | CFX | 1 | October 26, 2020 05:03 |
No liquid water exist in my Fuel Cell simulation | fatchang | FLUENT | 19 | October 15, 2018 15:27 |
New Solver for simple ground water flow | and | OpenFOAM Running, Solving & CFD | 1 | October 2, 2008 06:48 |
Simple algorithm for incompresible flow | Marek Dominiak | Main CFD Forum | 6 | April 26, 2008 04:43 |
