Intermittency output from Gamma Re Theta model
Old   August 23, 2017, 05:07
Default Intermittency output from Gamma Re Theta model
Totil is on a distinguished road
Dears,
I haven't started the CFD but I am writing a proposal and I need to know this that I can find nowhere.
How is the output of intermittency in the Gamma-Re_Theta transition model?
By this I mean, it is provided as BL profiles/contours at BL y position?
Can we get the intermittency on the wall?
I ask this because I will work with exp and cfd and I need to compare the intermittency. This issue is I only have meas. on the wall ...
* I read a report with intermittency profiles shaped like velocity, as if a no slip condition, where intermittency was always zero on the wall. If the model BC is normal zero flux of intermitency, we still can have the intermittency value on the wall, right?
** On Langtry's phd thesis and "Transition Modeling for General CFD Applications in Aeronautics" by Langtry and Menter is see contours if wall intermittency diff. than zero.
I appreciate the potential help you might give me!
Totil is offline   Reply With Quote
gamma theta model, intermittency, output, transition model
intermittency of transition SST model steven1 FLUENT 7 October 24, 2017 03:56
Gamma Theta Model Error dl467 CFX 4 November 26, 2015 08:52
Wrong flow in ratating domain problem Sanyo CFX 17 August 15, 2015 07:20
Superlinear speedup in OpenFOAM 13 msrinath80 OpenFOAM Running, Solving & CFD 18 March 3, 2015 06:36
Differences between serial and parallel runs carsten OpenFOAM Bugs 11 September 12, 2008 12:16
